18 Jan 2026 02:04
Replied by tommylight on topic Stepper Motor Shaft Failure
Category: Milling Machines
Can anyone confirm that this is a recognized risk with this arrangement ?
With a reduced shaft ?
I can not confirm, but i read a lot of Creality CR-30 3D printers have a failed motor shaft from factory, not reduced but long, and i do have a CR-30 that is still OK. The belt on those is 10mm wide and tight like a drum, literally.
The reason might also be the reduction on a lathe can leave grooves that might initiate the break due to tension and vibrations, so it seem plausible.
Best way to avoid this would be, granted the shaft is long enough, to make a bearing holder at the end of the shaft.
18 Jan 2026 01:56
Replied by tommylight on topic New and Working RTAI debs for 2.9
Category: Installing LinuxCNC
Well, with a value of 46872, Linux CNC runs at maximum speed, but if I change it to 50000 I get an error message.
Try 100000 , and also since you say it works better with 46872 try 93744.
This will limit your max velocity in half, use the "Max velocity" slider on screen to limit the speed till you do not get joint errors.
Notice the motor sound, should be much smoother.
I'd also like to ask a question: on a normal machine that is acceptable for running Linux CNC, what are the minimum and maximum acceptable values ​​for BASE_PERIOD?
There is no such thing, it all depends on what your PC can do safely, and from that set the drive microstepping to achieve the desired machine velocity/speed, if possible, as with low microstepping motors vibrate a lot.
I have a PC that does not skip a beat at 15000 but it's power supply failed (workstation=expensive), most mine do 50000-100000, and i have some bad laptops that are in daily use for over 10 years with base period set at 300000.
  • cnbbom
  • cnbbom
18 Jan 2026 01:34
Replied by cnbbom on topic New and Working RTAI debs for 2.9
tommylight and NWE
  • electrosteam
  • electrosteam
18 Jan 2026 01:23 - 18 Jan 2026 01:52
Stepper Motor Shaft Failure was created by electrosteam
Kondia FV-1 turret mill, running Gmoccapy 2.9.4.
Y-axis Nema 34 sheared the shaft at the step where the diameter had been reduced from 14 mm to 1/2" (and grubscrew).
Unknown if done by previous owner or factory option.
Drive uses an unsupported pulley with T10 x 25 mm timing belt and significant tension.
Both Y-axis and X-axis steppers replaced with new ones, with keyed 14 mm shaft.
John.
  • advangrootel
  • advangrootel
18 Jan 2026 01:14
Replied by advangrootel on topic need firmware for mesa 7i76eu+7i85+pwm
Category: Driver Boards
thanks a lot. tomorrow i try if it works. it is getting to late. the 7i85 board is not connected yet. i first want to make all working. then i will connect the encoders on the motors and connect the 7i85 board. what pins do i use without the 7i85 board to use the pwm?
  • rodw
  • rodw's Avatar
18 Jan 2026 00:55
Trying to move from UCCNC to Linuxcnc and using 7i96s but having trouble
Category: StepConf Wizard
If you have the limit switches, keep them. It does make for a safer machine. I used seperate min/max/home on my first machine but my next one I used a combined home/min limit switch only with no max limit.
  • rodw
  • rodw's Avatar
18 Jan 2026 00:49
Replied by rodw on topic How good is Ethercat motion control?
Category: EtherCAT
Another technical reason Ethercat is fast is that the slaves use custom Ethernet chips which can handle process data 'on the fly' without introducing delays.
That might have more to do with licensing. (the Ethercat license is paid for when purchasing a Ethercat sleve controller like the Lan9252 often used in slaves)
  • rodw
  • rodw's Avatar
18 Jan 2026 00:42
Category: EtherCAT
Ooops. Corrected the original post. I did realise I had got this wrong for the purists but was too lazy to battle with the forum editor.
  • nhof
  • nhof
18 Jan 2026 00:28
Replied by nhof on topic How good is Ethercat motion control?
Category: EtherCAT
Note that CNC is a small subset of Ethercat use as the majority of devices are deployed in factory automation. There are other field bus technologies mentioned in the PDF (and perhaps Mesa's hm2_eth driver) that compete but they are based on standard TCP/IP packets and while Ethercat also uses TCP/IP (perhaps TCP/IP are the wheels on the train). But Ethercat is much more efficient (lean) protocol so it performs better.
A small correction here, Ethercat does not use TCP/IP but instead uses 'raw' Ethernet frames.
18 Jan 2026 00:09
Has anyon e noticed smoother operation with linuxcnc vs other s when they switched?
Yes, many of my clients and friends, that is the first thing they notice when the machine starts moving after switching from Mach.
My liimit switches are only two wire.  Is this going to work?
Yes.
I have a threee wire home swithc set up hall sensor
Might be to late but, LinuxCNC can use a single switch for Homing and min/max limits, per joint/axis, so you do not need separate switches for limits and home.
3 axis machine = 3 switches total <<<< example
You can also use any combination of switches as you need/want.
  • NWE
  • NWE's Avatar
17 Jan 2026 23:59
Solving the USB Latency Dogma for HMI/MPG: Technical Feedback Request
Subject: Solving the USB Latency Dogma for HMI/MPG: Technical Feedback Request
Hi all,
I’d like to open a technical discussion about a project I’ve been working on, io_decoder, focusing on the software solution I've implemented to handle USB communication within LinuxCNC.
+1
More hardware support for LinuxCNC.
I am very much interested in this project. I have experience with embedded mcu applications, but zero experience doing development with the USB stack. Last year I was thinking that this type of I/O via USB connection should be developed, but did not find time to start on it.
I like the mechanical format of your boards, for edge-mounting them on a DIN rail.
Ethernet is very good for EMI prone applications, however, there are plenty use cases with less EMI where USB is just fine. For example, I have LinuxCNC reading an industrial position sensor through a cheap USB to RS232 dongle going on about 10 years by now. It substitutes for an encoder, providing feedback for a relatively slow moving PID controlled axis. This is on a setworks on a lumber mill, to set board thickness. The only interference problems they've had was of a mechanical nature, when a log jams in the wrong spot and rams the $2500 USD magnetorestrictive position sensor. It gets all bent out of shape, but lasts more than 5 years.
  • Mark Kraus
  • Mark Kraus
17 Jan 2026 23:46
Got it .  Spindle running and all axis running now just need to tune axis and get limits and encoders set up this is amazing after so many days I think this is going to be worth it because I have more of these conversions to do and I have learned so much it is amazing.  Without even tunning the spindle is behaving really well with no feedbac yet.  I was having trouble in uccnc wtih overshooting and taking awhile to get settled.  Has anyon e noticed smoother operation with linuxcnc vs other s when they switched?  The exciting thing for me is the prospect of ridgid tapping.  .  My liimit switches are only two wire.  Is this going to work?  I have a threee wire home swithc set up hall sensor
  • MaHa
  • MaHa
17 Jan 2026 22:31
Replied by MaHa on topic G-Code Schleifen
G-Code Schleifen
Category: Deutsch
Mit dieser Anpassung sollte das vollständig durchlaufen
    #2 = [#2 + 1]
   #1 = 0
o101 endwhile
  • PCW
  • PCW's Avatar
17 Jan 2026 22:18
Replied by PCW on topic need firmware for mesa 7i76eu+7i85+pwm
7I76EU firmware for 7I85 on P1, and 1 PWM on P3
File Name: 7i76eu_7i7...1pwm.zip
File Size:298 KB
After doing this I also had a thought that you could use a spare RS-422
output on the 7I85 for the PWM output, so you get a  buffered output
rather than a bare FPGA pin.
  • grandixximo
  • grandixximo's Avatar
17 Jan 2026 22:09 - 17 Jan 2026 22:12
Replied by grandixximo on topic LinuxCNC S-Curve Accelerations
 Thats a dodecadon lol
I was planning to make rounded corners actually be radiuses in the gcode G2 G3, probably next week, unless you want to oblige, many thanks again Rüdiger!
Displaying 7681 - 7695 out of 13514 results.
Time to create page: 0.412 seconds
