11 years 9 months ago - 11 years 9 months ago #55155 by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
You did all correct, my fault!
Thanks for reporting the bug, i will corect tomorow!
Norbert
P.S. to update, best is to use 2.6 buildnot repository!
Last edit: 11 years 9 months ago by newbynobi.
11 years 9 months ago - 11 years 9 months ago #55162 by Johnny-Don
Replied by Johnny-Don on topic Gmoccapy - A new screen for linuxcnc
newbynobi wrote: Hi Johnny-Don,
as Marius sayed, no file is attached to your post.
To do what you are trying, I would suggest:
Take a HAL_HBox or a HAL_Table and place your button in the containers. Both have an IN BIT Pin, controling if the child widgets are sensitive or not.
6.9. Containers: HAL_HBox and HAL_Table
Compared to their Gtk counterparts they have one input BIT pin which controls if their child widgets are sensitive or not. If the pin is low then child widgets are inactive which is the default.
Tip
If you find some part of your GladeVCP application is grayed out (insensitive), see whether a container’s pin is unset.
from GladeVCP docu
Now you only have to add a hal file to your embedded tab
EMBED_TAB_COMMAND = gladevcp -x {XID} -u ./usr/bin/paneljdj.py -H paneljdj.hal paneljdj.glade
and in this file you connect (check syntax!, as I am not on my linux computer and names are unclear):
net auto halui.mode.is_auto => not.in
net notauto not.out => hal_container.in
And it is done.
_______________________________________________________________________
If you realy want to import gmoccapy, you will have to check the following:
Is gmoccapy in your python path: In Ubuntu 10.04 it should be in
/usr/lib/pymodules/python2.6/gmoccapy
But it is not there!!!!
you will find a file named gmoccapy in /usr/bin/
copy this file to /usr/lib/pymodules/python2.6/gmoccapy/ and rename it to be gmoccapy.py
Now try again to import gmoccapy from gmoccapy and report.
All this is untested!!!
Norbert
Marius, thank you, I thought maybe it was awaiting approval.
Norbert, thank you a ton, I have not been on this project since last Thursday, but am back on it today. In light of your new info I dont see any point of posting my py file in it's current state. I am going to work out what you have suggested and give it a try. Thanks a bundle for the input, it never even crossed my mind to monitor HALUI pins. I will let all know how it goes.
Edit:
That works perfectly Norbert, thank you a ton! Below is the contents actual paneljdj.hal that I used. I had to re-do some things in my glade file to place all buttons in 'HAL Sensitive Tables' as they are called in Glade Interface Designer. What an amazing feature. I am a novice at Glade as well.
loadrt not count=1
addf not.o servo-thread
net auto halui.mode.is-auto => not.0.in
net notauto not.0.out => paneljdj.wheel_btn_tab
This has saved me many mores hours of painstaking work, I do appreciate it. Until next time, thank you!
Last edit: 11 years 9 months ago by Johnny-Don. Reason: Udpate
11 years 9 months ago #55292 by franstrein
Replied by franstrein on topic Gmoccapy - A new screen for linuxcnc
Norbert,
Thanks for your fast response and creation of gmoccapy 1.5.1.4.
That solved indeed my problem.
And the new buttons, turtle and rabbit jogging, are very useful.
For instance last night I was doing deep-drilling, using manual controls with the z-axis jogging button, doing slow drilling and fast retracts with the new button. :)
Keep up the good work and thanks,
Frans
11 years 8 months ago #55639 by Swapper
Replied by Swapper on topic Gmoccapy - A new screen for linuxcnc
mariusl wrote: Hi Norbert
I agree that we need some better touch off features. If you want to go that route with touch off then you might as well look at a lot more options like circle centres and many more.
IMHO we need a tab with touch off features and leave the run of the mill stuff as it is. Once you start down this road you will find that even the space at the bottom is not enough for what can be done.
The attached file shows what is a good set of touch off functions. That is why I think we need a tab for this.
You must also consider lathe users.
Would it be hard to dock this probe gui in gmoccapy?
linuxcnc.org/index.php/english/forum/40-...gcgui?start=30#37039
github.com/cnc-club/linuxcnc-features
Then all the "hard" probe stuff is done already.
11 years 8 months ago #55643 by andypugh
Replied by andypugh on topic Gmoccapy - A new screen for linuxcnc
Swapper wrote: Would it be hard to dock this probe gui in gmoccapy?
I am wondering if it could be created as a standalone GladeVCP "tab" that could be embedded into any GUI.
I have been thinking of setting up something similar as a tab in my Touchy config.
11 years 8 months ago #55762 by anarchos
Replied by anarchos on topic Gmoccapy - A new screen for linuxcnc
I use git for revision control on my ngc files, which works pretty well. I was able to hack in a button to gmoccapy in the "load a new file" selection dialogue that performs a "git pull" on the currently viewed directory to ensure the most recent file is being used. It works in a way (git actually executes) but the file list does not update until I go back a directory then back into the git controlled directory. Anyways, as I have no idea what I'm doing it's just a proof of concept, but I think it's pretty cool. Maybe there could be an option in the settings to enable/disable the button, and even customize the command that is being run on the button press? Or even better, only show the button when a .git file is present in the currently viewed directory.
The following user(s) said Thank You: dracozny
Moderators: newbynobi, HansU
Time to create page: 0.311 seconds
