11 years 9 months ago #54607 by LAIR82
Replied by LAIR82 on topic Gmoccapy - A new screen for linuxcnc
newbynobi wrote: I am not doing anything to that part,
at least till now ;-)
motion.tooloffset.x
motion.tooloffset.z
are handled by linuxcnc and is taken from the tool.tbl if the user emit an G43.
gmoccapy is only displaying them till now.
That stinks, oh well, I guess they aren't getting there wish anytime soon then, they wanted to be able to, at a glance see what they had on the table for those offsets
I also want a tool wear and the linuxcnc tooltable is the worst I have ever seen! It is limited in tool numbers, not database handled and does not support wear offsets. But be aware, it is something on my to do list, unfortunately, I am running out of time, and need also some more detailed information about linuxcnc internal tool handling.
Norbert
That would be wonderful!!! :)
That's why you never hear me yelling very loudly, good things come to those who are patient!!
I am not a programmer by no means, that's why I ask politely, and wait patiently.
Rick
11 years 9 months ago #54840 by ditechcnc
Replied by ditechcnc on topic Gmoccapy - A new screen for linuxcnc
Please add these option in lathe screen
and USB option in both screen
11 years 9 months ago #54864 by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
@ditechcnc
have you changed already some code? Or are the images only fake?
All you like, is possible with gmoccapy, just using custom glade panels, you can embed them in several places, so it is up to you to implement them.
and please publish the result, so others can use also the panels.
If you need help, we will be pleased to do so.
Norbert
11 years 9 months ago - 11 years 9 months ago #54865 by newbynobi
gmoccapy 1.5.0
ver. 1.5.0
  • new hal pin, and some renaming of hal pin to reflect the same names and behavior as halui-pin
  • * gmoccapy.jog-speed.counts
  • * gmoccapy.jog-speed.count-enable
  • * gmoccapy.jog-speed.direct-value
  • * gmoccapy.jog-speed.analog-enable
  • * gmoccapy.feed-override.counts
  • * gmoccapy.feed-override.count-enable
  • * gmoccapy.feed-override.direct-value
  • * gmoccapy.feed-override.analog-enable
  • * gmoccapy.spindle-override.counts
  • * gmoccapy.spindle-override.count-enable
  • * gmoccapy.spindle-override.direct-value
  • * gmoccapy.spindle-override.analog-enable
  • * gmoccapy.max-velocity.counts
  • * gmoccapy.max-velocity.count-enable
  • * gmoccapy.max-velocity.direct-value
  • * gmoccapy.max-velocity.analog-enable
  • gmoccapy will now react to some halui pin as counts or direct value. Be aware, that some of this may have side affects, it is strongly recomended to use the corresponding gmoccapy hal pin.
  • * halui.spindle-override.counts
  • * halui.feed-override.counts
  • * halui.max-velocity.counts
  • * halui.abort
  • * halui.spindle.start
  • * halui.spindle.stop
  • * halui.spindle.reverse
  • * halui.spindle.increase
  • * halui.spindle.decrease
  • * halui.program.run
  • * halui.program.stop
  • * halui.program.pause
  • * halui.mode.manual
  • * halui.mode.mdi
  • * halui.mode.auto
  • * halui.mist.on
  • * halui.mist.off
  • * halui.flood.on
  • * halui.flood.off
  • * halui.machine.on
  • * halui.machine.off
  • * halui.home-all
  • * halui.estop.activate
  • * halui.estop.reset
  • to reflect the new hal pin connections I introduced a new sim config gmoccapy_pendant.ini, demonstrating the connection of a remote pendant with selection switches
  • deleted gmoccapy_jog_wheels.ini, as pendant.ini demonstrates it better
Norbert
Last edit: 11 years 9 months ago by newbynobi.
11 years 9 months ago #54892 by ditechcnc
Images are fake
Please help me
Where can i create custom glade panels
11 years 9 months ago #54928 by Tom_R2E3
Replied by Tom_R2E3 on topic Gmoccapy - A new screen for linuxcnc
Hi Norbert.
Seems like there are lots of updates going on at the moment. I was wondering if you could remove the maximum (tool measurement) probe height of 100mm? I have three probe heights depending on what vice config I'm using, and one of them is more than 100mm high. At the moment I'm just subtracting an arbitrary 50mm from both probe height and block height when I use it.
Also, is it possible to recall the block height anywhere? Often I cant remember if I've set the block height or not and end up setting it again.
Many thanks,
Tom
Moderators: newbynobi, HansU
Time to create page: 0.735 seconds
