- dracozny
07 Feb 2015 16:28 #55769
by dracozny
Sliptonic uses github for ngc files as well as using it for whole machine builds and even gmoccapy conversions. Apparently some other projects too. It's nice to see and I found it somewhat helpful for my machine as well. github.com/sliptonic
I like your idea about incorporating github for your NGC files into your gui. Then you just need to incorporate something similar into an export script in your cad/cam software. would make editing on the fly very interesting.
Replied by dracozny on topic Gmoccapy - A new screen for linuxcnc
I use git for revision control on my ngc files, which works pretty well. I was able to hack in a button to gmoccapy in the "load a new file" selection dialogue that performs a "git pull" on the currently viewed directory to ensure the most recent file is being used. It works in a way (git actually executes) but the file list does not update until I go back a directory then back into the git controlled directory. Anyways, as I have no idea what I'm doing it's just a proof of concept, but I think it's pretty cool. Maybe there could be an option in the settings to enable/disable the button, and even customize the command that is being run on the button press? Or even better, only show the button when a .git file is present in the currently viewed directory.
- anarchos
08 Feb 2015 04:52 #55796
by anarchos
I just got that part working as well. I use HSMXpress in SolidWorks, so I edited my post processor to open up gitgui.exe after saving so I can commit the changes. I have my linuxcnc computer sharing it's harddrive to my windows computer, so I just save to Z:\ (what i mapped the linuxcnc computer to) so the git branch is stored on the linuxcnc computer but acts like a local branch as far as the windows computer is concerned. Works fairly well...now I just need to figure out how to actually modify gmoccapy without breaking stuff
Replied by anarchos on topic Gmoccapy - A new screen for linuxcnc
- Tom_R2E3
25 Feb 2015 23:40 #56294
by Tom_R2E3
Replied by Tom_R2E3 on topic Gmoccapy - A new screen for linuxcnc
Hi Norbert,
I just upgraded to 2.6.7 with Gmoccapy 1.5.2. Have the names of the override pins changed in the update? I get an error saying "pin gmoccapy.feed-override-counts does not exist"
If I remove the override lines from my custon_postgui.hal it launches fine.
Tom
Tom
- newbynobi
- Thank you received: 394
26 Feb 2015 06:16 #56301
by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Hallo Tom,
Yes, there have been small changes, to be uniform with the halui pin names.
The pin is called now gmoccapy.feed-override.counts
The doku in 2.6.7 should be up to date.
Norbert
Norbert
- Green#
02 Mar 2015 04:57 #56383
by Green#
Replied by Green# on topic Gmoccapy - A new screen for linuxcnc
Hello Norbert,
at first, thank you for create great GUI, looks really nice, but I need some help in implementation. Please let me know, can gmoccapy work with gantrykins? Now I trying to move configuration working on AXIS GUI based on gantrykins and under gmoccapy it doesn't work, there isn't any errors but it's impossible to move any axis. After change to trivkins, axises moves normally.
Best regards Przemek
- newbynobi
02 Mar 2015 23:42 #56408
by newbynobi
Hallo Przemek,
sorry for the late answer,
Gantrykins is not supported yet.
There will be some work in homing and jogging to make that work.
I will see what I can do.
Norbert
Norbert
- franstrein
05 Mar 2015 06:04 #56484
by franstrein
Replied by franstrein on topic Gmoccapy - A new screen for linuxcnc
While running gmoccapy 1.5.2 I think I found a small bug...
I do not yet have a virtual keyboard installed, need to configure that still.
Therefore the keyboard button on the UI is not active. That is correct.
However, I was exploring how to run my own macro from GMOCCAPY, and discovered that also the "Stop a running Macro'" button (Red cross?) on the same position in the UI is not active either.
Is this expected behavior, are should that button be active when executing the macro?
Thanks,
Frans
Thanks,
Frans
- newbynobi
05 Mar 2015 16:32 #56498
by newbynobi
Good found,
it is a bug!
Will correct that as fast as possible.
Norbert
it is a bug!
Norbert
- newbynobi
06 Mar 2015 04:47 #56506
by newbynobi
Macro Button Bug is solved, I have pushed 1.5.2.1 to 2.6 ; 2.7 and master
I also introduced a French translation!
Thanks for Francis for that beautiful work!
Norbert
Norbert
- tekmobile
09 Mar 2015 02:03 - 09 Mar 2015 02:04 #56548
by tekmobile
Replied by tekmobile on topic Gmoccapy - A new screen for linuxcnc
Just upgraded to 1.5.2 and getting this error when putting the spndle in reverse then trying to stop or go forward
Found an error!
The following information may be useful in troubleshooting:
File "/usr/bin/gmoccapy", line 2781, in on_rbt_reverse_clicked
self._set_spindle( "reverse" )
File "/usr/bin/gmoccapy", line 2819, in _set_spindle
rpm_out = rpm / self.stat.spindlerate
ZeroDivisionError: float division by zero
Found an error!
Last edit: 09 Mar 2015 02:04 by tekmobile. Reason: missing info
Moderators: newbynobi, HansU
Time to create page: 0.222 seconds
