- Thank you received: 394
- newbynobi
13 years 1 month ago #38406
by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Hallo Marius,
after an update please do the following:
after that copy :
gmoccapy_handler.py
gmoccapy.glade
The ICON folder (only needed if I do change ICON or renamed some. If you do not change ICON, it is best to just copy the folder)
to your own config folder.
If you want to use translation of the GUI, than you must copy the locale folder also to your config folder,
you do not have to delete your preference file.
Than it should work out of the box.
If I do change hal pin names or add new hal pin, I will advice that within the release notes. You will find that file in the sim/gmoccapy folder.
What is the exact error this time? I do suppose that icon view could not be registered, because that was the main changes I made.
Norbert
cd linuxcnc-dev
cd src
./autogen.sh
./configure
make
sudo make setuid
cd ..
. ./scripts/rip-environment
after that copy :
gmoccapy_handler.py
gmoccapy.glade
Norbert
- mariusl
13 years 1 month ago #38407
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
Hi Norbert
I usually do the complete cleanup and build after an upgrade. I think the problem here was two fold. As I have been testing a lot of Gscreen and Gmoccapy stuff, there could have been issues with the preference files. After I deleted them Gmoccapy would load but with errors of cannot find icon. I then copied the icons folder as well and the problem was solved.
I have written a script for my components to be copied to the right place and I will just add all the files as well as the icons to the list for Gmoccapy.
Just some feedback. The parts for my integrated controller is going for production this week so hopefully we will have the complete product running on a machine in the next couple of weeks. I am very excited about that. I will post some pictures once it is done.
Regards
Marius
www.bluearccnc.com
- newbynobi
13 years 1 month ago #38410
by newbynobi
@Marius,
Please report over the results of your test with the controller! And post as much photos you can!
That is exactly the use I made gmoccapy for!
Unfortunately I have to decide go on with the development of gmoccapy or build my own controller panel.
And at the moment I want to add my own error handling and some g-code generator from Rene, so there is still a lot of work to do!
Norbert
Norbert
- svenakela
13 years 1 month ago #38412
by svenakela
What? When I discovered Gmoccapy you are considering leaving it?! No way pal, you're stuck!
Replied by svenakela on topic Gmoccapy - A new screen for linuxcnc
newbynobi wrote: @Marius,
Norbert
- mariusl
13 years 1 month ago #38413
by mariusl
When it is done you can see if you like it. We can arrange for you to get one.
Regards
Marius
www.bluearccnc.com
Norbert
Regards
Marius
www.bluearccnc.com
- mariusl
13 years 1 month ago #38475
by mariusl
Regards
Marius
www.bluearccnc.com
Norbert
I tested the DRO problem again and this is what I found
With DTG set and you toggle between G54 and ABS you will find that the text colour that was selected in the settings tab was actually applied to the DRO background. So in short the background colour changes instead of the text colour.
Also I set the NO_FORCE_HOMING in my ini file but that is ignored. Is this supposed to be or is there a procedure here?
Regards
Marius
www.bluearccnc.com
Moderators: newbynobi, HansU
Time to create page: 1.926 seconds
