13 years 1 month ago #38629 by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Halo probamo,
no problem, only stupid people don't ask for help!
Please take a look on the WIKI and if you need more help...
gmoccapy wiko
We are her for that!
Norbert
13 years 1 month ago #38631 by jlviloria
Replied by jlviloria on topic Gmoccapy - A new screen for linuxcnc
Halo Norbert.
update the version and I have this error.
Next week I will send an email with some things I've been working, to see what you think.
13 years 1 month ago - 13 years 1 month ago #38632 by newbynobi
Halo Jorge,
I beleave that is an problem of your config. I just tested the actual version in a virtual machine and it works fine. I do beleave, that you still have in your config folder old gmoccapy files!
In your config folder should not be any of the following files:
gmoccapy_handler.py
gmoccapy.glade
no folder icon or locale
The structure of the files has been adapted to fit the new gscreen structure.
We look first in the config folder, if there is an handler file, if it is, we use that one, if not, then the search goes on in share/gsreen/skinns/gmoccapy if there isn't easer a handler file, than default gscreen will be used!
So please look at that first!
Norbert
By the way, why is your GUI not in spanish?
I only miss the translation file from you ;-)
Last edit: 13 years 1 month ago by newbynobi. Reason: explaining the error
13 years 1 month ago #38635 by mariusl
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
@marius,
Unfortunately I forgot to implement the NO_FORCE_HOMING patch,
I will push that as soon as possible!
Geez Norbert, I feel left out.:)
Not to worry as I am using the fix at the moment. It just means that I cannot upgrade until you have pushed again.
Regards
Marius
www.bluearccnc.com
13 years 1 month ago #38637 by svenakela
Replied by svenakela on topic Gmoccapy - A new screen for linuxcnc
Guys,
How production stable is Gmoccapy right now?
I am not there yet with my new VMC, at least a few more months, but I would like to use Gmpy on a router right now.
Is it master only or can it be patched to 2.5?
13 years 1 month ago #38645 by newbynobi
gmoccapy will only work on master!
IMHO it is stable! At least I am uskng it on a lathe and my testmill and till now i didn't find any problem!
Well, I tried on a Athlon with 800 MHz and 512 MB ram, but that machine is to slow.
Norbert
Moderators: newbynobi, HansU
Time to create page: 0.273 seconds
