- Thank you received: 2181
13 years 1 month ago #38745
Replied by cmorley on topic Gmoccapy - A new screen for linuxcnc
Great !
Thanks for trying that - now we can hopefully fix it quickly
Chris M
Chris M
- probamo
- Thank you received: 9
13 years 1 month ago #38757
by probamo
Replied by probamo on topic Gmoccapy - A new screen for linuxcnc
I would try to translate application in Serbian. Where can I find an English version, hence I can use the wording for translation?
Thanks,
Thanks,
13 years 1 month ago #38758
The correct way to do it is according to:
wiki.linuxcnc.org/cgi-bin/wiki.pl?Internationalization
Gscreen seems to be using the _("english text here") format so it should all work according to that description just by creating a Serbian .po file.
Replied by andypugh on topic Gmoccapy - A new screen for linuxcnc
probamo wrote: I would try to translate application in Serbian. Where can I find an English version, hence I can use the wording for translation?,
- newbynobi
- Thank you received: 394
13 years 1 month ago #38766
by newbynobi
That is really simple for gmoccapy, because all you need is on board!
Please go to
linuxcnc-dev/share/gscreen/skins/gmoccay/locale
Make a dir called cs (for Serbia) or es for Spain)
Copy gmoccapy.pot and gmoccapy.po to that dir,
change to that dir and
open that file with gtranslator (may you have to install it)
Normaly a doble click will open the file.
Now just translate all the strings and save the result as gmoccapy.po
Yes please override the po file!
No open the po file with poedit and just press Save.
After closing poedit there should be a new file called gmoccapy.mo
Make a folder named LC_MESSAGES and move the file gmoccapy.mo to that dir.
All done!
Do not delete the Po and pot files, because I I change code and you adapt the translation, we will need that files, so you do not need to translate everything again, but only the changes.
Would you please mail the translated files, so I will include them and they will be availible to everyone.
Norbert
There are also other ways, but that is the easiest IMHO.
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Thanks,
Please go to
All done!
Norbert
- newbynobi
13 years 1 month ago #38767
by newbynobi
gmoccapy 0.9.7.2 has been released
Marius,
that has been made only for you!
gmoccapy now works without homing if the INI file does include
NO_FORCE_HOMING=1
That is the only change, not exactly, I corrected also the release number
Norbert
Marius,
NO_FORCE_HOMING=1
Norbert
The following user(s) said Thank You: mariusl
- mariusl
13 years 1 month ago #38773
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
Thanks man, you are a champion.
Regards
Marius
www.bluearccnc.com
Moderators: newbynobi, HansU
Time to create page: 0.639 seconds
