13 years 1 month ago #38866 by svenakela
Replied by svenakela on topic Gmoccapy - A new screen for linuxcnc
Sounds good!
I'll will take the time and translate into Swedish within a week or so, have a LOT to do right now...
Need to get a touch screen and run it for real soon. :)
13 years 1 month ago - 13 years 1 month ago #38868 by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
gmoccapy - 0.9.7.3
- the buttons tbtn_view_dimension and tbtn_view_tool_path of the gremlin view
was in an undefined state after the start of gmoccapy. Now the state will be
set according to the state when leaving the GUI, default is show both
- the state view of gremlin was by default "p" no the state on leaving the gui
will be restored after restarting the GUI
- corrected an error entering the settings page, and aborting the dialog, then the
message appears two times, because the signal used was clicked and that is emitted twice
on a rbt when changing the state of the buttons in the group
Next to come: change order of buttons in auto mode
Norbert
Last edit: 13 years 1 month ago by newbynobi.
13 years 1 month ago #38971 by mariusl
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
Nortbert,
Is there a way to store widget (spinbox) values in a file. I need to add my user tab that contains a number of settings that I would like to store. There is a component written for Axis called paramsaver but it requires the pyvcp widgets to be modified with ans extra pin.
What do you suggest we do in this case?
Regards
Marius
www.bluearccnc.com
13 years 1 month ago #38975 by cmorley
Replied by cmorley on topic Gmoccapy - A new screen for linuxcnc
Unless Norbert adds something specific himself, it would require overriding the on_window1_destroy signal and adding a routine to save states.
see the gladevcp writeup for the basic idea.:
www.linuxcnc.org/docs/devel/html/gui/gla...ariables_in_gladevcp
The same idea could be used in gscreenn/gmoccapy
I assume you are using a customized version of Gmoccapy?
Chris M
13 years 1 month ago #38979 by mariusl
Chris,
No, I am trying to stay with the standard Gmoccapy screen and just put all my custom stuff in a user TAB.
Regards
Marius
www.bluearccnc.com
13 years 1 month ago #38994 by newbynobi
Halo Marius,
halo Chris,
I am not sure, but isn't it possible to open an own user tab, giving also a python file?
At least it is documentaded:
gladevcp -c gladevcp -u ../gladevcp/hitcounter.py -H ../gladevcp/manual-example.hal ../gladevcp/manual-example.ui
here you can find the doku:
gladevcp panels
If you just need an hal pin, that changes status when you close the GUI, that is easy to introduce, just tell me.
Norbert
Moderators: newbynobi, HansU
Time to create page: 0.445 seconds
