- jj89074
13 years 1 month ago #38723
by jj89074
Replied by jj89074 on topic Gmoccapy - A new screen for linuxcnc
I do not have that folder. The only folder under usr/share/gscreen is images and there are eight gif files there.
- Thank you received: 2181
13 years 1 month ago #38724
Replied by cmorley on topic Gmoccapy - A new screen for linuxcnc
Ok thanks you.
This is an installed version not a run-in-place version I assume.
If yes then we have to fix the install process - there are missing folders/files.
That may take a few days. Sorry
Chris M
Chris M
- jj89074
13 years 1 month ago #38725
by jj89074
I did a quick search for gmoccapy.glade also, but nada.
- jj89074
13 years 1 month ago #38726
by jj89074
Yes, it is an installed version.
If I run the commands from the gmoccapy wiki in the terminal, I do get the latest version of gmoccapy to run (under rip-environment from the linuxcnc-dev folder).
I'm not able to find what files need to be transferred to run my configuration from the linuxcnc folder and not the linuxcnc-dev folder. I hope that makes sense.
13 years 1 month ago #38728
The files I spoke of are missing in an installed version.
In a RIP version they are found in [RIP_FOLDER_NAME}/share/gscreen/skins/gmoccapy/
If you copied that file to /usr/share/gscreen/gmoccapy
Then it should work fine.
But better would be to wait for use to sort this out properly.
Chris M
Chris M
- jj89074
13 years 1 month ago #38738
by jj89074
Chris,
I copied the skins folder like you suggested and the "sim" configuration of gmoccapy works as it should with no errors given...thank you!
Jim
Jim
Moderators: newbynobi, HansU
Time to create page: 0.183 seconds
