13 years 1 month ago #39184 by probamo
Replied by probamo on topic Gmoccapy - A new screen for linuxcnc
Translation looks good, but still needs fine tuning. That's why I wanted to check it out before sending to you. Still polishing required.
I looks like I would do the entire installation again. Although I deleted dev dir and redo installation again as wiki recommendation, I Terminal I got the following message (in attachment). Real-time is quite good.
13 years 1 month ago #39188 by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Halo,
You can not start linuxcnc while latency test is still running!
If the errors occur bevore you start latency test, then there is a real problem with you linuxcnc installation!
13 years 1 month ago #39189 by probamo
What ever was, I reinstalled system :laugh:
Now I am IN again.
It works everything. Now, how can I change the LANG in application to check the length and rephrase if necessary.
Thanks,
13 years 1 month ago #39190 by newbynobi
probamo wrote: What ever was, I reinstalled system :laugh:
You do not have to change anything in the GUI, just make a folder in:
~/linuxcnc-dev/share/gscreen/skins/gmoccapy/locale
call it "cs" for Serbian
make i subfolder called "LC_MESSAGES" (case sensitive)
and place here your gmoccapy.mo file.
After start of the GUI it should start in the new language.
If it does not, then your locale settings are not according to the folder name.
In that case please go to a terminal and enter : $LANG
There should come something like cs_CS.utf8
Please keep me informed, I will add every change to your translation files to master.
Norbert
13 years 1 month ago #39191 by probamo
Instead of "cs" please make "rs" for Serbia.
I'll give a try.
13 years 1 month ago - 13 years 1 month ago #39192 by probamo
Look my screenshot. I created folder "rs", though there is "de" and "es", but neither German or Spanish is loaded. In Terminal there is en-US. How to change it.
Thanks.
Last edit: 13 years 1 month ago by probamo. Reason: forgot attachements
Moderators: newbynobi, HansU
Time to create page: 0.346 seconds
