- Thank you received: 9
- probamo
13 years 1 month ago #39368
by probamo
Replied by probamo on topic Gmoccapy - A new screen for linuxcnc
Done. Thanks
- newbynobi
- Thank you received: 394
13 years 4 weeks ago #39510
by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
gmoccapy 0.9.8 is on its way
ver. 0.9.8
- introduced notification as gmoccapy error messaging system
- rebuild the settings page to make the message
system settings available
- new default start-up position
- changed DRO text color label to DRO background color label,
because that is what you change
- jogging with keyboard will jog full speed if SHIFT
is hold down
- <Super_L> key will delete the last message of
gmoccapy message system
- <STRG>+<SPACE> delete all gmoccapy messages at once
- switching on the machine will reset the GUI to manual mode
- the setup button is no longer a member of the
mode radiobuttons it is now a toggle button,
so pressing it twice will bring you to manual mode
- corrected add added translations for
Spanish and German prepared the files for Serbian
I will be away for a week o so, please wait for Chris to push my patch.
Norbert
ver. 0.9.8
is hold down
Norbert
- Thank you received: 2181
13 years 4 weeks ago #39524
Replied by cmorley on topic Gmoccapy - A new screen for linuxcnc
Norbert:
Iwas going to push but got an error.
I don't see anything obvious....
- newbynobi
13 years 3 weeks ago - 13 years 3 weeks ago #39529
by newbynobi
Hallo Chris,
I don't see any error in my code. I am just putting up a new virtual machine and test on that one.
Hope to get this solved, before getting my plane;-)
If you are not sleeping jet, I am on IRC channel!
Norbert
Norbert
Last edit: 13 years 3 weeks ago by newbynobi.
- newbynobi
13 years 3 weeks ago #39530
by newbynobi
OK Chris,
that is a problem on your system I beleave!
I just put up a complete new virtual machine, and make a new git pull. I got then gmoccapy 0.9.7.5.1 as I should.
I tested it and it works just fine.
Than I made:
git apply gmoccapy_0_9_8.patch
I got trailing whitspace warnings, 16 whitespace errors and 21 lines and whitespace errors, but alls as warnings, the patch did apply correctly.
(I have to check what this whitespace errors are to avoid them in future releases)
I start than linuxcnc and selected gmoccapy. I got 0.9.8 with all features running fine.
What should I do now?
Norbert
Than I made:
Norbert
13 years 3 weeks ago #39568
You should sit back and enjoy your trip
Yes it was a problem on my system: a notification.pyc file still present from when I tried your program last time
I have now pushed your work to master.
Safe trip.
Chris M
Safe trip.
Chris M
Moderators: newbynobi, HansU
Time to create page: 0.783 seconds
