13 years 1 month ago #39334 by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
halo Dejan,
nearly all you mentioned is solved, I send a new patch to Chis.
As soon as he pushed that, I will give more details.
Norbert
13 years 1 month ago - 13 years 1 month ago #39353 by newbynobi
gmoccapy_0_9_7_5 - translation and small bugs solved
ver 0.9.7.5
- Serbian translation now included, meaning gmoccapy is now available in 4 languages,
English, German, Spanish and Serbian
- translation of the Continuous Jog Button now possible
- solved a bug, when selecting the contentious jog button when it was translated
- added ABS, DTG and GTD to translation file
- added "show or hide tool path" to translation
- corrected a bug changing spindle bar min and max values changed the widget only on restart
- added to translation the complete gscreen.py file, even if there are a lot of things
nobody need to translate, but that gives the possibility to translate the entry dialogs
and some button labels, i.e. run from line
Jorge: Would you please check the Spanish translation.
Dejan: Please add the missing translations to Serbian translation
Unfortunately I missed to change the cersion number in the handler file, so you will see still 0.9.7.4.
Sorry for that! I will make now a patch to correct that!
Norbert
Last edit: 13 years 1 month ago by newbynobi.
13 years 1 month ago #39361 by probamo
Replied by probamo on topic Gmoccapy - A new screen for linuxcnc
No problem Ićll do so, just shortlz, how can I update gmoccapy. I tried git pull but something went wrong.
13 years 1 month ago #39363 by newbynobi
Halo Dejan,
a git pull should work!
What went wrong?
Norbert
13 years 1 month ago #39364 by probamo
I am not familiar how it works, but attached is comment I got from Terminal.
Thanks,
13 years 1 month ago - 13 years 1 month ago #39365 by newbynobi
Easy to solve, you are just in the wrong directory!
cd linuxcnc-dev
git pull
should work ;-)
Last edit: 13 years 1 month ago by newbynobi. Reason: typo
Moderators: newbynobi, HansU
Time to create page: 0.355 seconds
