- Thank you received: 394
- newbynobi
13 years 3 weeks ago #39575
by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Thanks Chris,
I will now enjoy my holidays.
Norbert
Norbert
- probamo
- Thank you received: 9
13 years 3 weeks ago #39620
by probamo
Replied by probamo on topic Gmoccapy - A new screen for linuxcnc
Hereafter attched are files in Serbian.
- newbynobi
13 years 2 weeks ago #39873
by newbynobi
Halo Dejan,
the translation has been added and pushed.
Norbert
Norbert
- newbynobi
13 years 2 weeks ago #39875
by newbynobi
@All,
is there a need to get gmoccapy to control also plasma cutters?
I did some work on that, but I do not now exactly how that should work, so I would need help in making an sim plasma cutter.
I tried to copy part of plasma-thc-sim, but I did not get it to work.
So, should I invest some more time, or isn't there a need for plasma cutters?
See the screenshot for a first layout.
Replacing the tool Info frame and the spindle and coolant frames is allready possible with custom glade files, but not jet documented.
Norbert
Norbert
- mariusl
13 years 2 weeks ago - 13 years 2 weeks ago #39877
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
Hi Norbert
Hope you had a nice holiday.
YES YES YES please. I had just started to look at that as I do lots of plasma machines. I have just finished developing a THC controller that has the following pins: Most of the THC controllers on the market has the same but not all has the ARC VOLTAGE feedback. The THCAD form Mesa does have feedback.
THC SET VOLTS -> PWM signal from LCNC
ARC VOLTS <- analog signal that I read with a SPI type component
ARC OK <- once the plasma has established the pilot arc and ready to move
TORCH UP <- tell the component to pick up the Z axis
TORCH DOWN <- tell the component to drop the Z axis
There is also a THC RATE which is s percentage of the maximum feed rate. When you are in run mode you dont have the luxury of acceleration settings so you must make sure that the Z axis acceleration during THC control does not cause the motor to slip.
There are more things that we could discuss. I will assist if you want.
With regard to the simulator, that is going to be very hard as you dont have the actual plasma functions.
EDIT: - Norbert something I am missing on your picture is the plasma cut height. One has to set cut height, pierce height and travel height.
Regards
Marius
www.bluearccnc.com
Last edit: 13 years 2 weeks ago by mariusl.
- cncbasher
- Thank you received: 202
13 years 2 weeks ago #39880
by cncbasher
Replied by cncbasher on topic Gmoccapy - A new screen for linuxcnc
yes Norbert Plasma screen would be good .
Moderators: newbynobi, HansU
Time to create page: 0.182 seconds
