13 years 2 months ago #38083 by mariusl
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
Looking good Norbert thanks a lot.
Regards
Marius
www.bluearccnc.com
13 years 2 months ago #38127 by svenakela
Replied by svenakela on topic Gmoccapy - A new screen for linuxcnc
Great GUI! Must test it. Master is getting too good, I might start using it in the workshop.
13 years 2 months ago #38313 by mariusl
Norbert
There seem to be a problem with the DRO display. The colours dont work out. The background seem to be a problem
Regards
Marius
www.bluearccnc.com
13 years 2 months ago #38320 by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
@Marius,
can you explain a little bit more your problem?
I do not know why, but after changing the colors you must restart one time gmoccapy and thän everythink shoul work like it should.
And do not mix preferences from gscreen and gmoccapy, this can give additional problems, that's why I do recommend an own preference file setting in the INI file.
Norbert
13 years 2 months ago #38331 by mariusl
Norbert
My own config does not work at all after the update but I will look at that by itself. I then loaded the sim example and found that the DRO background and font color was red. So you could not see the text. I changed the text color but then the background stays red on the areas where there is no text.
I did a clean and rebuild but it remains the same.
Regards
Marius
www.bluearccnc.com
13 years 2 months ago #38332 by mariusl
Norbert
With the sim I deleted all the preference files and started over. It seems that the problem is gone.
Please tell me what are the files that need to be in my own config directory in order to run gmoccapy? I want to make a script that will copy all the right stuff after an upgrade. I have problems every time that I upgrade and I am sure that it is not necessary.
Regards
Marius
www.bluearccnc.com
Moderators: newbynobi, HansU
Time to create page: 2.205 seconds
