12 years 11 months ago #40563 by mariusl
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
Norbert I think the plasma.py.txt file that you uploaded is corrupt. This is what is inside.
Please repost that.
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN"> <html><head> <title>500 Internal Server Error</title> </head><body> <h1>Internal Server Error</h1> <p>The server encountered an internal error or misconfiguration and was unable to complete your request.</p> <p>Please contact the server administrator, webmaster@linuxcnc.org and inform them of the time the error occurred, and anything you might have done that may have caused the error.</p> <p>More information about this error may be available in the server error log.</p> <p>Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.</p> </body></html>
Regards
Marius
www.bluearccnc.com
12 years 11 months ago #40601 by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Halo Marius,
you are right, the file is corrupt. I do not know why, may be, because the forum does not allow uploading python files.
I just send you the correct one by separate mail. After adding the file, you should see also the second panal.
Norbert
12 years 11 months ago #40602 by newbynobi
Hallo,
this is the content of plasma.py
# This is only to show, that you can implement also your # own python callbacks. import linuxcnc import os class Plasma: def __init__(self,halcomp,builder,useropts): inifile = linuxcnc.ini(os.getenv("INI_FILE_NAME")) self.builder = builder self.THC_StepSize = self.builder.get_object("THC_StepSize") value = inifile.find("PLASMA","THC_StepSize") self.THC_StepSize.set_value(float(value)) self.TravelHeight = self.builder.get_object("TravelHeight") value = inifile.find("PLASMA","TravelHeight") self.TravelHeight.set_value(float(value)) self.TravelGap = self.builder.get_object("TravelGap") value = inifile.find("PLASMA","TravelGap") self.TravelGap.set_value(float(value)) self.SwitchTravel = self.builder.get_object("SwitchTravel") value = inifile.find("PLASMA","SwitchTravel") self.SwitchTravel.set_value(float(value)) self.PierceDelay = self.builder.get_object("PierceDelay") value = inifile.find("PLASMA","PierceDelay") self.PierceDelay.set_value(float(value)) self.PierceGap = self.builder.get_object("PierceGap") value = inifile.find("PLASMA","PierceGap") self.PierceGap.set_value(float(value)) self.Piercing_auto = self.builder.get_object("Piercing_auto") value = inifile.find("PLASMA","Piercing_autostart") self.Piercing_auto.set_active(int(value)) self.HeightLock = self.builder.get_object("HeightLock") value = inifile.find("PLASMA","enable_HeightLock") self.HeightLock.set_active(int(value)) self.CHL_Threshold = self.builder.get_object("CHL_Threshold") value = inifile.find("PLASMA","CHL_Threshold") self.CHL_Threshold.set_value(float(value)) self.THC_TargetVoltage = self.builder.get_object("THC_TargetVoltage") value = inifile.find("PLASMA","THC_TargetVoltage") self.THC_TargetVoltage.set_value(float(value)) def on_btn_torch_toggled(gtkobj,data=None): if gtkobj.get_active(): print("active") else: print("not active") def get_handlers(halcomp,builder,useropts): return(Plasma(halcomp,builder,useropts))
Norbert
12 years 11 months ago #40647 by mariusl
Thanks Norbert, all working now. I have started with the component but it is going to take a while as I have to test it very well. I am snowed under with work at this time but lucky it is all plasma machines so I will get enough opportunity to test.
Regards
Marius
www.bluearccnc.com
12 years 11 months ago #40652 by sliptonic
Replied by sliptonic on topic Gmoccapy - A new screen for linuxcnc
I've been playing with migrating my mill config from Axis to Gmoccapy and I'm really impressed. With the touchscreen, it's a pleasure to use. Thank you.
The only thing I haven't found is a way to toggle the spindle brake. If I need to customize this myself, I'd like to replace the coolant mist button with the brake toggle since I don't have mist.
Is there a guide to basic customization that I haven't found?
Thanks again!
12 years 11 months ago - 12 years 11 months ago #40657 by DaOne
Replied by DaOne on topic Gmoccapy - A new screen for linuxcnc
I am having a problem with the lathe screen in imperial mode. The diameter is displaying metric while the radius is showing imperial. I also show metric in the "Max Velocity" box when I jog the axis.
In my ini I have it setup for imperial like this...
[TRAJ] LINEAR_UNITS = inch [RS274NGC] RS274NGC_STARTUP_CODE = G18 G20 G40 G49 G54 G80 G90 G94 G8 M9 M5 G64 P0.005
Here is a screen shot...
Is there another setting I need to make or is this a bug?
Thanks,
Wes
Last edit: 12 years 11 months ago by DaOne.
Moderators: newbynobi, HansU
Time to create page: 0.186 seconds
