15 Mar 2014 17:34 - 15 Mar 2014 17:39 #44840 by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Halo Marius and all the others interested in python glade and gmoccapy:
Here you can download Aptana Studio 3
Attached are my settings, with optimized Code Highlight and adapted style to be most PEP8 conform:
(you will have to uncompress before import)
How To Import Settings
And second attachment is the skeleton for custom panel with hide hal pin for Marius ;-)
Just copy the 4 files to sim/gmoccapy and start hiding_panel.ini for testing.
See the source code py file for a lot of comments and hints and the ini file for how to embed this.
Norbert
Last edit: 15 Mar 2014 17:39 by newbynobi.
The following user(s) said Thank You: mariusl, balestrino
15 Mar 2014 18:42 #44842 by mariusl
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
Ha Norbert must be the nicest guy on this forum. ;) Thanks a lot man, not only did you solve the problem but you also caused me to get committed to learn Python and GladeVCP.
I was getting frustrated by not being able to take full advantage of many of the LCNC features due to my lack of knowledge of Python.
I am sure a lot of other people will also benefit from your efforts here.
Regards
Marius
www.bluearccnc.com
15 Mar 2014 18:56 #44843 by mariusl
Just tested it, bloody amazing man. Now we can do some stuff :whistle:
This screen just gets better and better.
Regards
Marius
www.bluearccnc.com
15 Mar 2014 19:05 #44844 by mariusl
Norbert
Do you use the workspace the same as your config directory?
Regards
Marius
www.bluearccnc.com
15 Mar 2014 20:47 #44849 by newbynobi
Hallo Marius,
no, please do not use the config dir as Aptana workspace dir. Use the default in your home instead, otherwise you will get a lot of files in your linuxcnc-dev directory witch are not needed and cause only problems in case of building a patch or pushing changes.
Norbert
15 Mar 2014 21:12 #44851 by mariusl
Hi Norbert
Sorry for the twenty questions. Is there a way to run just this panel from the terminal or do we need the full Gmoccapy to load?
Regards
Marius
www.bluearccnc.com
16 Mar 2014 19:09 #44877 by newbynobi
Halo Marius,
yes and no is the answer.
Open a terminal and start gmoccapy
open an other terminal and after also gibing rip-environment enter
gladevcp hiding_panel.glade
or
gladevcp -u hiding_panel.py hiding_panel.glade
Norbert
16 Mar 2014 20:06 #44879 by mariusl
Ahh Ok. I take it the panel that you are working on does not have to be loaded in Gmoccapy, only in the second terminal.
Regards
Marius
www.bluearccnc.com
17 Mar 2014 01:08 #44885 by newbynobi
Just pusher 1.0.9,
it solves a "Ignore Limit" bug.
Norbert
17 Mar 2014 10:54 #44909 by jbunch
Replied by jbunch on topic Gmoccapy - A new screen for linuxcnc
Hi Norbert,
I went to use Gmoccapy today to turn some parts and the spindle readout is not the same.
In Forward I get the spindle speed of 500 rpm and a spindle at speed light.
In reverse I now get a negitive spindle speed -500 rpm with no spindle at speed light.
I have a back tool lathe it spends most of it's time in reverse.
Is this a change you have made?
Is this the way it will be from now on?
I have changed nothing in my config files except the disply section and
changes to posthui.hal required for Gmoccapy.
Jim
Moderators: newbynobiHansU
Time to create page: 1.216 seconds
