- verser
- Thank you received: 69
06 Mar 2014 05:14 - 06 Mar 2014 05:15 #44468
by verser
Replied by verser on topic Gmoccapy - A new screen for linuxcnc
This problem occurs when in .ini file erase important lines or assigned too large values
Last edit: 06 Mar 2014 05:15 by verser.
- verser
06 Mar 2014 05:19 - 06 Mar 2014 05:26 #44469
by verser
For example here, theseor
# Highest value that will be allowed for feed override, 1.0 = 100%
MAX_FEED_OVERRIDE = 1
MAX_SPINDLE_OVERRIDE = 1.2
MIN_SPINDLE_OVERRIDE = 0.25# Max and default jog speeds in units per second
MAX_LINEAR_VELOCITY = 18
DEFAULT_LINEAR_VELOCITY = 18
MAX_ANGULAR_VELOCITY = 18
Last edit: 06 Mar 2014 05:26 by verser.
- mariusl
06 Mar 2014 13:00 #44478
by mariusl
Hi Norbert
It is always there. I shut down the terminal and restarted linuxcnc and the number is there. It seems to be the same number all the time. Something generated from within the Glade maybe?
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
Hallo Marius,
I have never seen such numbers on my PC !
May be it is one of your bit-coins, trying to escape
Can you reproduce that behavior? I guess it is more a problem on your computer.
Norbert
Hi Norbert
Regards
Marius
www.bluearccnc.com
- hobride
06 Mar 2014 14:19 #44479
by hobride
Replied by hobride on topic Gmoccapy - A new screen for linuxcnc
Off topic!
is that a bottle of vodka?
No, verser is nickname.
I promote your interface in Russian forum
cnc-club.ru/forum/viewtopic.php?f=15&t=4575&p=110957#p110957
- verser
06 Mar 2014 14:27 - 06 Mar 2014 14:28 #44480
by verser
Yeah, and on the machine - boobs
Last edit: 06 Mar 2014 14:28 by verser.
- newbynobi
- Thank you received: 394
06 Mar 2014 15:37 #44481
by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
@verser,
I tried your examples, but I did not get the numbers on my screen.
@Marius,
Please try the following:
get from git the actual glade file and replace the existing one.
Then try again.
If it is still there, please mail me a copy of your config folder.
Norbert
@Marius,
Then try again.
Norbert
- verser
06 Mar 2014 16:03 #44483
by verser
even just a little bit and Compensation Z will be ready with the correct version of the connection
@verser,
Norbert
[DISPLAY]
EMBED_TAB_NAME = my_new_panel
EMBED_TAB_LOCATION = box_custom_2
EMBED_TAB_COMMAND = gladevcp -x {XID} -u compensation_z.py -H compensation_z.hal compensation_z.gladePlease Log in or Create an account to join the conversation.
- mariusl
06 Mar 2014 16:17 #44484
by mariusl
What do you mean with "the actual glade" ? I did a fresh pull after a hard reset last night. Did you push another version since then?
Regards
Marius
www.bluearccnc.com
@Marius,
Then try again.
Norbert
Regards
Marius
www.bluearccnc.com
- newbynobi
06 Mar 2014 16:32 - 06 Mar 2014 16:33 #44485
by newbynobi
Hallo Marius,
no, I did not push a new version, but I want to avoid errors because of old resting files on your computer. I am not sure how make handles files witch exist.
Just go to:
latest glade
Click right on the blue gmoccapy.glade and select save as to save it on your computer.
It belongs to linuxcnc/share/gmoccapy
Then try.
Norbert
Just go to:
latest glade
Then try.
Norbert
Last edit: 06 Mar 2014 16:33 by newbynobi.
- mariusl
06 Mar 2014 18:24 #44489
by mariusl
Regards
Marius
www.bluearccnc.com
Norbert
I deleted all my repositories and reinstalled from master. These number only appear in my config.
I run the rotary_mill_253.ini
Regards
Marius
www.bluearccnc.com
Moderators: newbynobi, HansU
Time to create page: 0.278 seconds
