02 Mar 2014 23:56 #44318 by mariusl
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
Yes of coarse it is required. There is s lot of files that is being moved or deleted and the complete make proses will sort out all that for you automatically. Also if you do not compile you will not have the latest binaries in the correct places.
Do This every time:
git pull
cd /src
./autogen.sh
./configure
make
sudo make setuid
Regards
Marius
www.bluearccnc.com
02 Mar 2014 23:59 #44319 by hobride
Replied by hobride on topic Gmoccapy - A new screen for linuxcnc
ok thanks,
i will try this
03 Mar 2014 00:01 #44321 by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
I just pushed two new fixes, so actual version is 1.0.3
Norbert
03 Mar 2014 01:02 #44324 by mariusl
Hi Norbert
I just did a fresh pull and the version is showing 0.9.9.8.1. Is there a catch somewhere ?
Regards
Marius
www.bluearccnc.com
03 Mar 2014 01:18 #44327 by newbynobi
Hallo Marius,
I just pushed 1.04, so you should find that version,
see here :
03 Mar 2014 01:18 #44328 by newbynobi
Hallo Marius,
see here :
Git Master Repo
Norbert
03 Mar 2014 02:18 #44332 by hobride
hello all,
i get it now, it works fine. thanks again.
and i see the right version number 1.0.4
03 Mar 2014 02:48 - 03 Mar 2014 02:50 #44333 by aralel
Replied by aralel on topic Gmoccapy - A new screen for linuxcnc
Hi guys.
At start i wanna tell you, my english is not very good ;p
I'm new with linux and linux cnc.
I have already installed up to date gmoccapy but have a problem to connect it with my maschine becose i don't know how to configure parports or import setup from linuxcnc 2.5.3 stepconf :/
Please if u can tell me step by step how to do it.
Thank's for responce
i send you terminal log from start gmoccapy
"linuxcnc" is the name of my computer
File Name: log.txt
File Size:2 KB
Last edit: 03 Mar 2014 02:50 by aralel. Reason: try to add file
03 Mar 2014 03:29 #44335 by mariusl
Hi Norbert
I am trying to do a pull but get this error now.
From git://git.linuxcnc.org/git/linuxcnc
   0a70d3f..ce3f0ec  master     -> origin/master
Updating 7897a27..ce3f0ec
error: Untracked working tree file 'lib/python/stepconf/__init__.py' would be overwritten by merge.  Aborting
Regards
Marius
www.bluearccnc.com
03 Mar 2014 03:45 #44336 by cmorley
Replied by cmorley on topic Gmoccapy - A new screen for linuxcnc
as a work around :
git reset --hard origin/master
Warning this will delete any customizations of the tracked source code.
It resets your repo to whatever linuxcnc's master is.
Chris M
Moderators: newbynobiHansU
Time to create page: 0.359 seconds
