- Tom_R2E3
I'm not at my mill at the moment but the axis sim behaves as you'd expect (pause then stop stops the program). The gmoccapy sim behaves as described above, (pause then stop jumps to the next tool change). Can check them both at my physical machine later.
Many thanks, Tom
- mariusl
how would you go about getting external feed and spindle overrides to work in Gmoccapy. I'm using those cheep encoder switches from eBay and using the mpg inputs (16,17,18,19) on the mesa 7i77 card. I can see the enable and the a and b phases switch on in the show hal but the count does not work.
Is your 7i77 encoder input selected for digital? The default is usually set for differential input. I have some of those mpg's and will use them shortly on my lathe.
Regards
Marius
www.bluearccnc.com
- papaours
www.dropbox.com/sh/21w4c5arxa3b9ho/AACmY...zsUbsvfGvRdcbAa?dl=0
- LAIR82
- Thank you received: 3
Hallo Rick,
I tried with an own program and could not reproduce that behavior. I do quiet often pause a program, measure an diameter, stop the program, make a new touch off or change tool offsets and then start a new run of the program. I never had any behavior as you mentioned.
I will need a program of yours to reproduce the behavior. Otherwise I will not be able to check where it comes from and will not be able to fix it.
IMHO it should not be a gmoccapy issue, as I am using only linuxcnc commands to run a program, but I will check that as soon as I got the sample program.
Norbert
Sorry for the delay Norbert, I have been so busy, I didn't realize you replied to this.
I will get a program, and post it for you.
The operator isn't even pausing it, the program stops on the MO1, as it should, and waits to be restarted, but sometimes the operator will just hit the "program stop" button (to theroretically abort, and reset the interpreter) and then "program start" ( which should start from the first line of the program), but I looks like it is starting off at the first coordinated G01 move, that is maybe 5-10 lines down in the program, totally bypassing the tool change, spindle command, and other modal codes.
Rick
- Thank you received: 4648
That sounds like a different problem. (though possibly related).
- Connor9220
- microsprintbuilder
- newbynobi
- Thank you received: 394
It is may be related to the STOP / RESUME / START bug i just solved.The operator isn't even pausing it, the program stops on the MO1, as it should, and waits to be restarted, but sometimes the operator will just hit the "program stop" button (to theroretically abort, and reset the interpreter) and then "program start" ( which should start from the first line of the program), but I looks like it is starting off at the first coordinated G01 move, that is maybe 5-10 lines down in the program, totally bypassing the tool change, spindle command, and other modal codes.
I checked all possibilities and could not reproduce that. But if the user did not press STOP, but twice the PAUSE, than I get a similar behavior.
So if you update to 1.3.1 the behavior should be gone.
Please check and confirm!
Norbert
- newbynobi
update to 1.3.1, as you are suffering also under the mentioned bug.
Norbert
- LAIR82
Thanks Norbert,
Rick
