12 years 1 day ago #52617 by mariusl
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
Have look at this document, it contains all the information that you need to install from scratch.
wiki.linuxcnc.org/cgi-bin/wiki.pl?Instal..._the_source_with_git
Regards
Marius
www.bluearccnc.com
12 years 23 hours ago - 12 years 23 hours ago #52618 by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
How did you install the version you are running?
What version do you have now installed?
Please check the WIKI for Update infos. If there are still questions, do not hesitate to ask.
Norbert
P.S. If you are brave, you can also follow: Update to 2.7 buit you will not get the very last version. Actual package contains 1.3.0. So better use git version.
Last edit: 12 years 23 hours ago by newbynobi.
12 years 18 hours ago #52627 by papaours
Replied by papaours on topic Gmoccapy - A new screen for linuxcnc
Good evening,
i have a fresh install ( 1 months ) with 2.6 live Debian. on a DVD
Actually Gmoccapy is 1.2 and i am afraid of STOP PAUSE crash.
I have try to play with git, but no result.
so git is installed, and all is update, but Gmoccapy is alway 1.2
i will try harder tomorrow morning.
Thank you very much.
One question regardind calling a gcode file.
My cam software (windows computer ) print a barre code for each sheet of a job, ( 1 job = +/- 50 sheet = 50 gcode )
i would like to store all the file on a server, and use a barre code reader to call it instead of using the mouse.
Gmoccapy do not allow me to see the last file i have run.
And Sometime i run tow time the same Gcode...
12 years 16 hours ago #52633 by newbynobi
Hallo papaours,
if git is installed, just do:
git clone git://git.linuxcnc.org/git/linuxcnc.git linuxcnc-dev sudo apt-get install libboost-python-dev libmodbus-dev libusb-1.0-0-dev cd linuxcnc-dev cd src ./autogen.sh ./configure make sudo make setuid cd .. . ./scripts/rip-environment linuxcnc
If you installed allready the depencies and cloned git, just ignore the steps.
gmoccapy allows to set up the start dir and also a jump to dir to select files, so if the files to use are all in the same dir, just set the jump to dir to that path.
Norbert
Norbert
12 years 15 hours ago #52634 by papaours
Thank you, i will try it.
12 years 13 hours ago #52637 by Tom_R2E3
Replied by Tom_R2E3 on topic Gmoccapy - A new screen for linuxcnc
Hi Norbert,
Will that be 2.6.3 then, or 2.8? I had a go on my spare machine (following the instructions for Debian on the Wiki page) and got 2.8 pre.
Tom
Moderators: newbynobi, HansU
Time to create page: 0.260 seconds
