11 years 11 months ago #52730 by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Tom,
unfortunately that bug is known! It is caused from the remap procedure, sending a program load/change signal to the hal_sourceview widget and the preview widget.
I have looked at it for quiete a while and I have a solution in mind, but because of leek of time I could not work it out and present is to the other developers.
It is more a work around, let the coresponding hal procedure check the program name and if it begins with "remap_" ignore the change, not sending a signal.
Give me time to work that out.
Norbert
11 years 11 months ago #52758 by Tom_R2E3
Replied by Tom_R2E3 on topic Gmoccapy - A new screen for linuxcnc
Hi Norbert, thanks for getting back to me.
No problem. Is there a list of known bugs somewhere? I've noticed a couple of other things but they may well have already been reported.
Basher,
I am sensing the input through an input pin on mesa 7i77 hardware. The inputs sense +DC and have an internal resistor, they must be pulled down when disconnected. My setter is 24v DC and earths through the cutter. To get the 7i77 to sense this I rooted it through a spare relay. I bet that's offensive to anyone who knows about electronics, but I'm an ignorant mechanical engineer. Think a circuit with a transistor would have been better..
tom
11 years 11 months ago #52771 by newbynobi
Hallo Tom
I only know from two "bugs", one with teh preview using remap and the other one is mentioned in the WIKI, "strange numbers in the info frame".
If you have something more, please let me know.
Norbert
  • microsprintbuilder
  • Premium Member
  • Premium Member
11 years 11 months ago #52772 by microsprintbuilder
Replied by microsprintbuilder on topic Gmoccapy - A new screen for linuxcnc
Tom, As per mesa tech you could put a 100 ohm resistor from the 7i77-?? input to the + volts on you 7i77 and switch you hal input to -not I did this with some prox switches that switched to ground when active and it worked just fine.
11 years 11 months ago #52776 by Tom_R2E3
Microsprintbuilder, that's a good suggestion, I'll try that, thank you!
Norbert, I've only noticed minor things.
One is that since the update from 1.2 to 1.3, gmoccapy no longer remembers that I don't want to show the keyboard on any pages (I just uncheck the boxes now whenever I start gmoccapy)
The other is with coordinate systems: If you're making some moves in G54 everything is normal, the DRO shows G54 and it's also listed in the "G-code" part of the screen. If your program then changes to say G55, the machine responds correctly, but the DRO and G-code list still display "G54", it's a bit confusing. This is only the case in Auto mode, if you do the same exercise in MDI the DRO will show the correct coordinate system..
The following user(s) said Thank You: newbynobi
11 years 11 months ago #52778 by cncbasher
Replied by cncbasher on topic Gmoccapy - A new screen for linuxcnc
Tom,
a relay is too slow for this , can you give details of the setter your using , an opto or simple transistor will do
and in fact with some setups you may not need anything , the output of the setter should just go to a 7i77 pin , you may need to invert the gpio pin in your hal file
are you using 24v as your field power on the 7i77 ?
Moderators: newbynobi, HansU
Time to create page: 0.195 seconds
