- Tom_R2E3
11 years 11 months ago #52662
by Tom_R2E3
Replied by Tom_R2E3 on topic Gmoccapy - A new screen for linuxcnc
Excellent, all working now, thanks for the help.
Tom
Tom
- papaours
11 years 11 months ago - 11 years 11 months ago #52665
by papaours
Replied by papaours on topic Gmoccapy - A new screen for linuxcnc
To Norbert
That is OK, but why you go on if you get an error????
Have you not seen :
checking for library containing Tcl_Init... no
configure: error: tcl lib not found
So why did you go on?
Please correct the error by installing : tcl
Are you on UBUNTU 14.04 ?
After getting no more errors on configure, you can do
Make
sudo make setuid
. ./scripts/rip-environment
I am definitly not good about Linux and terminal command,
This is why i have wait so long to get Gmoccapy, i was waiting to have it work on a stable version of Linuxcnc.
So here i am, i have Download the 2.6 Live+Install image and rebuild my hard disk to make Gmoccapy runing.
It was serve with Debian instead of Ubuntu, dont know why, but it is ok for me.
Eccept for Dropbox wont work very well, ( not at all ) on debian.
So i am asking just one thing.
Having a Safe MACHINE and Get actual gmoccapy 1.3.X instead of the Gmoccapy 1.2 offered for the STABLE Linuxcnc install
I am shur, if nothing is done in a near future with a new realease 2.6.4 to correct the Pause Stop problem of Gmoccapy, some one will Break his machine soon and
will be very hungry.
( As an expample, my ATC Spindle rebuilt cost is around 4500 euro ........and it take at least one month. )
THank you very much.
Mael.
Have you not seen :
Make
sudo make setuid
Mael.
Last edit: 11 years 11 months ago by papaours.
- newbynobi
- Thank you received: 394
11 years 11 months ago #52668
by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
Hallo Mael,
ok, Now I do know you are on Debian Hybrid ISO.
so after installing tcl with
sudo apt-get install tcl
should bring you to a stable release.
Please check on every step for errors and if there are some, please report it, so we can help.
Norbert
cd linuxcnc-dev
git checkout 2.7
cd src
make clean
./autogen.sh
./configure
make
sudo make setuid
cd ..
linuxcnc
Norbert
- cncbasher
- Thank you received: 202
11 years 11 months ago #52685
by cncbasher
Replied by cncbasher on topic Gmoccapy - A new screen for linuxcnc
Mael:
i also use debian hybrid iso , so if you are still having difficulty let me know and i will help
their is now no need to use development version
you should have an update to linuxcnc 2.6.4 available now , that has the updates to gmocappy to solve your problem
Dave
Dave
The following user(s) said Thank You: papaours
- Tom_R2E3
11 years 11 months ago #52701
by Tom_R2E3
Hi Norbert,
At the weekend I made a tool setting probe so that I could use the tool measurement in Gmoccapy. It's an excellent addition to my mill, I can wind the knee up or down during the tool change without having to touch off any tools!
I do have a question/bug though. After running the subroutine to measure the tool, the machine continues with my program, but the G code viewer (below the DRO in auto mode) continues to show the tool measurement subroutine. Sometimes it switches back to displaying my program, and sometimes it sticks on the subroutine, it depends which tool I have changed to! I've played around with my tool table but I cant work out the difference between the ones which work and the ones which cause the bug.
Hope that description made sense.
Many thanks, Tom
Many thanks, Tom
- cncbasher
11 years 11 months ago #52714
by cncbasher
Tom ,
sound like it could be noise or the pin needs debounce
have you a pullup on the pin to 5v ?, or perhaps fit a transistor as a ttl switch , to make the transition sharper
i also use screened cables , vfd's can make a mess of low voltage signals
Moderators: newbynobi, HansU
Time to create page: 0.657 seconds
