11 years 11 months ago #53058 by mariusl
Replied by mariusl on topic Gmoccapy - A new screen for linuxcnc
Todd Zuercher wrote: What happens if you end your program with just a % instead of an M2 or M30?
I did not know about the difference between using the % and M2/M30. I will have to go loo at all the ngcgui and lathemacro files to make sure that they end with %. I have had programs that does not load if I use the % operator but I will have to go look at this a bit more clearly.
Regards
Marius
www.bluearccnc.com
11 years 11 months ago #53072 by newbynobi
Replied by newbynobi on topic Gmoccapy - A new screen for linuxcnc
my question is, how to I access the signals any widgets (buttons, LED, etc) I might add to my glade file? For instance, I have a custom HALoutput pin for PSI on my application, and I would like to display that in my custom tab, how would I go about doing so?
Do you use hal_widgets? If so, you should see the corresponding hal pin after starting the gui. Just connect them in your posthui.hal file. If you get problems, please post your complete config folder.
Norbert
The following user(s) said Thank You: Johnny-Don
11 years 11 months ago #53243 by verser
Replied by verser on topic Gmoccapy - A new screen for linuxcnc
Hi Norbert,
whether а gmoccapy can alert the errors of g-code when loading g-code program?
11 years 11 months ago #53248 by newbynobi
Hallo verser,
I am looking for a solution, unfortunately the glade widgets do not have that option yet.
But it is on my to do list.
Norbert
11 years 11 months ago #53252 by DaBit
Replied by DaBit on topic Gmoccapy - A new screen for linuxcnc
Bug in gmoccapy, or LinuxCNC itself?
The preview in gmoccapy had problems in the Y axis. Scaling and positioning is incorrect.
Using the sim.axis/axis_mm.ini everything is OK:
Running 2.8.0~pre1 as RIP.
Regarding the M2/M30 vs % sign: I did not dive deeply into it, but I still saw a switch back to G54 instead of G59
11 years 11 months ago #53253 by newbynobi
Hallo,
Could you please post the gcode file?
I will try to reproduce that here on my mill.
Norbert
Moderators: newbynobi, HansU
Time to create page: 0.398 seconds
