- Thank you received: 2100
Another plasma component...
- phillc54
7 years 6 months ago #130819
by phillc54
John,
No worries at all, I can always find something to do...
Thank you for all your testing.
Cheers, Phill.
Cheers, Phill.
- phillc54
7 years 6 months ago #130821
by phillc54
I have pushed a couple of minor updates:
- show thc as locked until target voltage established at start of cut
- change all stop on error to pause on error
Cheers, Phill.
Cheers, Phill.
- JTknives
- Thank you received: 32
7 years 6 months ago #130822
by JTknives
Replied by JTknives on topic Another plasma component...
- phillc54
7 years 6 months ago #130824
by phillc54
I have pushed another update:
- fix torch pulse and ohmic test while paused
Cheers, Phill.
JTknives, I will try a fresh git clone on my workshop machine and get back to you.
Cheers, Phill.
Cheers, Phill.
Cheers, Phill.
- Thank you received: 4153
7 years 6 months ago #130825
JT Knives, as mentioned earlier, the problem is (I think) that you built your plasmac config as the root user either becasue root was logged in or you used sudo when compiling. In this instance, that means you as the user does not have permissions that are required to run LinuxCNC. So it is finding the other config
- phillc54
7 years 6 months ago #130826
by phillc54
This should be:
The one you cloned is my fork of linuxcnc so you would have master branch...
I just completed a brand new install and it does work...
Cheers, Phill.
JTknives wrote:
jtknives@plasma:~$ git clone github.com/phillc54/linuxcnc.git ~/plasmac
This should be:
git clone https://github.com/phillc54/linuxcnc-plasmac ~/plasmac
Cheers, Phill.
Time to create page: 1.681 seconds
