- Thank you received: 216
Another plasma component...
- islander261
7 years 6 months ago #130731
by islander261
Replied by islander261 on topic Another plasma component...
Phill
Thank you. I will most likely not be able to do any testing today because it is suppose to be dry outside after 6 days of rain. At this time of year you can see the grass growing here.
I hope others may weigh in on this so we can see if some sort of consensus can be found . As you know I feel strongly about having a torch enable button and indicator on the GUI. The torch enable signal is ANDed with any torch on signal coming from the controller just prior to connecting to the output pin. On my system a dry run is done any time you run a Gcode program and the torch is disabled. I find that once you get your PP sorted out there isn't much use for a dry run ( I only ever cut full sheets).
I will fall back to using M1 to pause the program on tool change so I can switch the THC enable from the config panel for now.
- phillc54
- Thank you received: 2100
7 years 6 months ago #130745
by phillc54
Cheers, Phill.
Yes, that would be good, I do rely on others as I have no experience with plasma operation...islander261 wrote:
I hope others may weigh in on this so we can see if some sort of consensus can be found.
Cheers, Phill.
- Thank you received: 7491
7 years 6 months ago #130747
Replied by tommylight on topic Another plasma component...
To tired to weight in on anything, need some sleep.
As far as i can absorb, it is going pretty well. Plasma cutting is simple only for watching bystanders.
Regards,
Tom.
Regards,
Tom.
- phillc54
7 years 6 months ago #130754
by phillc54
Cheers, Phill.
Cheers, Phill.
- Thank you received: 4153
7 years 6 months ago #130765
I learnt that too!
phillc54 wrote: HAHA, I definitely know that now...
Cheers, Phill.
I learnt that too!
- JTknives
- Thank you received: 32
7 years 6 months ago #130780
by JTknives
Replied by JTknives on topic Another plasma component...
I think I'm closer but still getting errors. I now see the plasmac when I run LinuxCNC from a terminal. I select imperial from the axis sim But it Fails. I then open pncconf wizard and point it to the new folder in the config folder. I run through that and save. Then I look for the Hal file with the address and change that to 10.10.10.10 but still errors out. Not sure what I'm doing right or wrong.
Time to create page: 0.564 seconds
