- Thank you received: 2100
Another plasma component...
- phillc54
7 years 6 months ago #130651
by phillc54
I have just pushed another update:
Add ohmic-max-attempts pin, this is the number of ohmic probe attempts before fallback to float switch.
Add probe-start-height and ohmic-max-attempts to all the sample configs.
Remove some redundant code.
Fix some typos and general housekeeping.
Cheers, Phill.
Cheers, Phill.
The following user(s) said Thank You: chimeno, rodw
- Zultan
- Thank you received: 3
7 years 6 months ago #130653
by Zultan
If you followed those directions exactly then I suspect that you have compiled the default master branch of linuxcnc.
If you were to follow the guide again but replace:
with:
You would then have to compile the code in the linuxcnc-plasmac directory rather than the linuxcnc-dev.
After you have cloned the Phil's repo from git you can enter the linuxcnc-plasmac directory to ensure that ./configs/sim/axis/plasmac exists.
Hope this helps
Glenn
Replied by Zultan on topic Another plasma component...
JTknives wrote: Yeah I read through that entire page thats how i was able to get it installed. but when I go looking for these after i type in linuxcnc thy are not listed
Sample Configurations/sim/axis/plasmac
Sample Configurations/sim/gmoccapy/plasmac
Sample Configurations/sim/qtvcp_screens/plasmac
> git clone git://github.com/linuxcnc/linuxcnc.git linuxcnc-dev
> git clone https://github.com/phillc54/linuxcnc-plasmac.git linuxcnc-plasmac
Hope this helps
Glenn
- islander261
- Thank you received: 216
7 years 6 months ago #130668
by islander261
Replied by islander261 on topic Another plasma component...
Phill
Just amazing all that happens when I am away for a couple of days making deliveries.
I will fix my PP today to produce some working code for use with your plasmac branch. Do I need to do anything except update my install from git? Thanks for all the hard work.
- phillc54
7 years 6 months ago #130698
by phillc54
John,
Yes, a git update should be all you need.
Cheers, Phill.
Cheers, Phill.
- islander261
7 years 6 months ago #130700
by islander261
Phill
Cut a sheet of parts out today. I think there are a few problems. Here is a video of some of the cutting:
I hope the link works as I really don't know what I am doing with all video stuff. Sorry it is on it's side, rotate monitor or head.
1. Torch always returns to Z max (G53 G0 Z0) every probe. Torch goes to safe Z at end of cut and rapids to next cut, then raises to Z max then probes.
2. On probing error torch stays at safe Z most of the time instead of raising to Z max.
3. IHS skip appears to be broken, tried several settings and none worked, this makes for a slow cut job.
4. Shorted tip probing error is very sensitive compared to my branch, no change in HW.
5. Ohmic Probe button MUST be active when program is paused to check for shorted torch, right now you have no way to check if you actually got the torch clean.
6. Torch pulse button MUST be active when program is paused so you can clear water and debris from plate surface.
7. Had a couple of "lost" in logic events during probing when torch went past Z max and tripped limit switch.
8. What has happened to .thc-enable-ext pin? My thc enable from Gcode is now broken.
TIA for all the hard work.
- phillc54
7 years 6 months ago #130702
by phillc54
Thanks John, I will get right on it...
Cheers, Phill.
Cheers, Phill.
Time to create page: 0.390 seconds
