- Thank you received: 32
Another plasma component...
- JTknives
- JTknives
7 years 6 months ago #130797
by JTknives
Replied by JTknives on topic Another plasma component...
Yeah that’s what I want
- JTknives
7 years 6 months ago #130798
by JTknives
this is what it gives me if i try and run linuxcnc from that screen
jtknives@plasma:~/linuxcnc-plasmac/scripts$ . rip-environment
This script only needs to be run once per shell session.
jtknives@plasma:~/linuxcnc-plasmac/scripts$ linuxcnc
LINUXCNC - 2.8.0~pre1
Machine configuration directory is '/home/jtknives/linuxcnc/configs/sim.axis.plasmac.gladevcp'
Machine configuration file is 'imperial_plasmac.ini'
Starting LinuxCNC...
twopass:invoked with <> options
twopass:found /home/jtknives/linuxcnc-plasmac/lib/hallib/basic_sim.tcl
twopass:found ./plasmac.hal
setup_kins: cmd=loadrt trivkins coordinates=xyyz
twopass:pass0: loadusr -W hal_manualtoolchange
HAL: ERROR: exit called before init
twopass: load_the_modules cmd=<orig_loadrt trivkins coordinates=xyyz>
waitpid failed /home/jtknives/linuxcnc-plasmac/bin/rtapi_app trivkins
/home/jtknives/linuxcnc-plasmac/bin/rtapi_app exited without becoming ready
insmod for trivkins failed, returned -1
twopass: load_the_modules cmd=<orig_loadrt motmod base_period_nsec=32000 servo_period_nsec=1000000 num_joints=4>
waitpid failed /home/jtknives/linuxcnc-plasmac/bin/rtapi_app motmod
insmod for motmod failed, returned -1
twopass: load_the_modules cmd=<orig_loadrt pid names=J0_pid,J1_pid,J2_pid,J3_pid>
waitpid failed /home/jtknives/linuxcnc-plasmac/bin/rtapi_app pid
insmod for pid failed, returned -1
twopass: load_the_modules cmd=<orig_loadrt mux2 names=J0_mux,J1_mux,J2_mux,J3_mux>
waitpid failed /home/jtknives/linuxcnc-plasmac/bin/rtapi_app mux2
insmod for mux2 failed, returned -1
twopass: load_the_modules cmd=<orig_loadrt ddt names=J0_vel,J0_accel,J1_vel,J1_accel,J2_vel,J2_accel,J3_vel,J3_accel>
waitpid failed /home/jtknives/linuxcnc-plasmac/bin/rtapi_app ddt
insmod for ddt failed, returned -1
twopass: load_the_modules cmd=<orig_loadrt hypot names=hyp_xy,hyp_xyz>
waitpid failed /home/jtknives/linuxcnc-plasmac/bin/rtapi_app hypot
insmod for hypot failed, returned -1
twopass: load_the_modules cmd=<orig_loadrt sim_home_switch names=J0_switch,J1_switch,J2_switch,J3_switch>
waitpid failed /home/jtknives/linuxcnc-plasmac/bin/rtapi_app sim_home_switch
insmod for sim_home_switch failed, returned -1
twopass: load_the_modules cmd=<orig_loadrt sim_spindle names=sim_spindle>
waitpid failed /home/jtknives/linuxcnc-plasmac/bin/rtapi_app sim_spindle
insmod for sim_spindle failed, returned -1
twopass: load_the_modules cmd=<orig_loadrt limit2 names=limit_speed>
waitpid failed /home/jtknives/linuxcnc-plasmac/bin/rtapi_app limit2
insmod for limit2 failed, returned -1
twopass: load_the_modules cmd=<orig_loadrt lowpass names=spindle_mass>
waitpid failed /home/jtknives/linuxcnc-plasmac/bin/rtapi_app lowpass
insmod for lowpass failed, returned -1
twopass: load_the_modules cmd=<orig_loadrt near names=near_speed>
waitpid failed /home/jtknives/linuxcnc-plasmac/bin/rtapi_app near
insmod for near failed, returned -1
twopass: load_the_modules cmd=<orig_loadrt debounce cfg=3>
waitpid failed /home/jtknives/linuxcnc-plasmac/bin/rtapi_app debounce
insmod for debounce failed, returned -1
twopass: load_the_modules cmd=<orig_loadrt plasmac>
waitpid failed /home/jtknives/linuxcnc-plasmac/bin/rtapi_app plasmac
insmod for plasmac failed, returned -1
Note: Using POSIX realtime
LinuxCNC terminated with an error. You can find more information in the log:
/home/jtknives/linuxcnc_debug.txt
and
/home/jtknives/linuxcnc_print.txt
as well as in the output of the shell command 'dmesg' and in the terminal
- islander261
- Thank you received: 216
7 years 6 months ago #130799
by islander261
Replied by islander261 on topic Another plasma component...
Ok
Now open a new terminal session and try:
and pick any of the plasmac sims. If it doesn't run copy and past the text from the terminal into a message using <code></code> or text file. Both are easier for me to deal with than using screen photos. BTW in your accessories menu your distribution should have a screen capture program listed and installed.
It is getting close to time to decide which UI you are going to want to try using.
. linuxcnc-plasmac/scripts/rip-environment
linuxcnc
- islander261
7 years 6 months ago #130800
by islander261
I will have to go to the shop to use a working config so it may be up to hour or so before I have a real reply. In the mean time open a new terminal and try exactly this:
It does matter where you start from. Same as your last post, copy and paste terminal output into message. And I will get back ASAP.
jtknives@plasma:~$ . linuxcnc-plasmac/scripts/rip-environment
jtknives@plasma:~$ linuxcnc
- Thank you received: 7491
7 years 6 months ago #130802
Replied by tommylight on topic Another plasma component...
It looks like you ran the make with sudo the first time, you have twice in the log files "permission denied".
I do not know how to fix that, maybe someone else will chime in.
Time to create page: 0.306 seconds
