- Thank you received: 2100
Another plasma component...
- phillc54
Was the thc-enable-ext pin in the plasmac.comp I posted on this thread, If so could you please post it here as I cannot find a copy and I cannot find it any commits to the branch.
Cheers, Phill.
- islander261
- Thank you received: 216
I have not been careful about keeping a full backup before each change so I can't quickly find the file. From my .hals the pin was plasmac_panel.thc-enable-ext and as I recall the pin was created in plasmac_panel.py. It may also have made it to plasmac_config.py. Sorry for the poor configuration management. This isn't a big thing as I can always add an OR2 and make the connection outside of the handler file (as it probably should be).
Nothing for you to do but I think I am going to add more LEDs to the plasmac_monitor.glade panel to indicate when the THC is enabled from the Gcode and when the torch is enabled (i don't feel good about not have an explicit torch enable button). A spare will fill the empty spot until I find another thing.
- phillc54
I was looking in the commits at the comp file, now I know where it is I should be able to find it.
Cheers, Phill.
- Thank you received: 4153
JTknives wrote: Yeah I read through that entire page thats how i was able to get it installed. but when I go looking for these after i type in linuxcnc thy are not listed
Sample Configurations/sim/axis/plasmac
Sample Configurations/sim/gmoccapy/plasmac
Sample Configurations/sim/qtvcp_screens/plasmac
if you open a terminal window, type
If it does not point to the folder you compiled plasmac into eg (maybe its pointing to ~/linuxcnc-dev), then you have not set the environment as I stated.
So linux looks at this variable to decide in which folder it looks for linuxcnc and we all think its looking in the wrong place....
- phillc54
Fixed, I confused myself with probe height being the distance above the stock when it really should be distance above the slats.islander261 wrote:
1. Torch always returns to Z max (G53 G0 Z0) every probe. Torch goes to safe Z at end of cut and rapids to next cut, then raises to Z max then probes.
At the moment all error conditions that cause a pause go to safe height and all error conditions that cause a stop go to Z max.2. On probing error torch stays at safe Z most of the time instead of raising to Z max.
Should all errors go to Z max regardless.
Also maybe all errors should pause and then the operator has the choice of what to do...
It appears to work ok here, I did make a couple of minor chages but they don't affect the operation.3. IHS skip appears to be broken, tried several settings and none worked, this makes for a slow cut job.
I used the Gmoccapy imperial config with imperial_plasmac_squares.ngc and did a Dry Run and a simulated cut.
The cut offset in this program is 1.414"
If I set SkipIHS to 1.4 it probes every start.
If I set SkipIHS to 1.5 it goes directly to pierce height.
Is that the "ohmic probe detected before probing" error?4. Shorted tip probing error is very sensitive compared to my branch, no change in HW.
Fixed.5. Ohmic Probe button MUST be active when program is paused to check for shorted torch, right now you have no way to check if you actually got the torch clean.
Fixed.6. Torch pulse button MUST be active when program is paused so you can clear water and debris from plate surface.
I couldn't duplicate that, maybe something to do with my incorrect math in item 1.7. Had a couple of "lost" in logic events during probing when torch went past Z max and tripped limit switch.
I forgot to mention that I took that out a while ago as I could not get consistant results and I was going to look at it again but I got sidetracked.8. What has happened to .thc-enable-ext pin? My thc enable from Gcode is now broken.
I will look at this later when we get the basics working.
Cheers, Phill.
- phillc54
I am happy to try to add and/or modify anything you think is required.
Cheers, Phill
