- Thank you received: 2100
Another plasma component...
- phillc54
7 years 6 months ago #130580
by phillc54
Please note that I have removed the attachment from
this post
as there is an error that could inadvertently turn on the torch while probing...
Working on a solution.
Cheers, Phill.
Cheers, Phill.
- phillc54
7 years 6 months ago - 7 years 6 months ago #130586
by phillc54
I have just pushed an update:
Probing should be fixed...
Add a pin named probe-start-height, when probing Z will rapid down at the setup speed and when it gets to this height will move down at probe speed. If this is left at 0 then Z will move down at probe speed.
I have not added a spinbox into any of the sim configs yet...
Next step is to allow multiple ohmic-attempts before falling back to float switch. At the moment it is whatever occurs first.
A bit of feedback on this would be good.
If we set ohmic-max-attempts to 1, does that mean:
1: Try a probe, if ohmic unsuccessful go to probe start height then probe again, accepting either ohmic or float switch
or does it mean:
2: Try a probe, if ohmic unsuccessful keep probing until float switch
I am leaning toward 1, then 0 would behave as per 2 which would be the setting if you had no ohmic probe..
Cheers, Phill.
or does it mean:
Cheers, Phill.
Last edit: 7 years 6 months ago by phillc54.
- JTknives
- Thank you received: 32
7 years 6 months ago #130643
by JTknives
Replied by JTknives on topic Another plasma component...
You kinda lost me. I flowed the how to that was included with the download. But I did not see any plasmac and I don't really know how to compile or change a git. Sorry I feel so out of my league here.
- phillc54
7 years 6 months ago #130645
by phillc54
Have a read through
this document
to get a bit of background on building LinuxCNC.
Have you seen the "quick look" section of the first post in this thread.
Cheers, Phill.
Cheers, Phill.
- JTknives
7 years 6 months ago #130646
by JTknives
Yeah I read through that entire page thats how i was able to get it installed. but when I go looking for these after i type in linuxcnc thy are not listed
Sample Configurations/sim/axis/plasmac
Sample Configurations/sim/gmoccapy/plasmac
Sample Configurations/sim/qtvcp_screens/plasmac
- phillc54
7 years 6 months ago #130648
by phillc54
You need to run LinuxCNC exactly as described in the first post or as described by Rod
above
Cheers, Phill.
Cheers, Phill.
Time to create page: 3.208 seconds
