- Thank you received: 216
Another plasma component...
- islander261
7 years 6 months ago #130417
by islander261
Replied by islander261 on topic Another plasma component...
Phill
A quick update. Probing with the float switch works as it should. Is this because with the float switch the movement is so much greater(.005" vs .115")?
- phillc54
- Thank you received: 2100
7 years 6 months ago #130418
by phillc54
John,
I am not quite sure what is happening. Did you try the plasmac comp I posted above . It is different to the one in the branch.
Cheers, Phill.
Cheers, Phill.
- islander261
7 years 6 months ago - 7 years 6 months ago #130419
by islander261
Phill
There is/was no attachment at this end.
I am a very poor coder but it looks to me the difference is that the float switch logic is looking for the float switch offset to not be exceeded and there is no such offset for ohmic probing. I can see how the travel can easily exceed zero_target with no sheet deflection and a bit of debounce.
I know why this wasn't a problem before. I was doing the line test cuts on the skeleton of sheet that I had already cut productions parts out of. So I was testing on a pre warped very flexible piece of material.
Last edit: 7 years 6 months ago by islander261.
- phillc54
7 years 6 months ago #130420
by phillc54
Sorry John, I must have pressed the go button before my poor old brain had caught up...
Cheers, Phill.
Cheers, Phill.
- phillc54
7 years 6 months ago - 7 years 6 months ago #130421
by phillc54
I see you show the arc voltage as an integer. Is this normal practice for plasma?
Cheers, Phill
John,islander261 wrote:
Please see attached screen shoot on my new screen
Cheers, Phill
Last edit: 7 years 6 months ago by phillc54.
- islander261
7 years 6 months ago #130443
by islander261
Phill
I just want a display that isn't jumping around too much.
I am different than most users in that I mostly cut one material and thickness. So if we use the HT rule that you need to hold your cut distance to better than +/-.005" for good cut quality. This is about +/- 6 arcvolts on my system (.070"/74v=.000810811in/v). If you are using standard Duramax consumables you are closer to +/-11v. I find on my system using a THCad card for arc voltage measurement that I get about .1 to .2 scaled volts noise whether I am cutting or not. So for me not seeing any fractions is ok. On the system I built I can only set the arcvoltage to a 1v resolution.
Time to create page: 1.087 seconds
