- Thank you received: 2100
Another plasma component...
- phillc54
7 years 6 months ago #130475
by phillc54
This machine is actually an old wheezy install with a parallel port so it is running RTAI and it only has a wifi.
I finally managed to get it going, it was a corrupt resolv.conf file, probably something I did earlier, this sort of crap happens often when your are in your sixties...
The good news is that even with my shonky probe setup I get exactly the same issues John was having here so I am confident that I can get this working...
Cheers, Phill.
Cheers, Phill.
- Thank you received: 4153
7 years 6 months ago #130479
Please do not say that. There are others in that age group too!
phillc54 wrote: This sort of crap happens often when your are in your sixties...
Cheers, Phill.
- phillc54
7 years 6 months ago - 7 years 6 months ago #130480
by phillc54
John,
I think I have it working now. I am using a go pin .002" small and a nogo pin 0.003" large and the heights for both ohmic and float are consistently within them. I also have the debounce set to 1.
[strike]New plasmac.comp is attached.[/strike]
Cheers, Phill.
EDIT: attachment removed, there is an error in this file that can inadvertently turn the torch on while probing...
Cheers, Phill.
Last edit: 7 years 6 months ago by phillc54.
The following user(s) said Thank You: chimeno
- islander261
- Thank you received: 216
7 years 6 months ago #130518
by islander261
Replied by islander261 on topic Another plasma component...
I believe most if not all the active participants in this area are there or close to it.
Phill, thanks for all the hard work on this.
- phillc54
7 years 6 months ago #130527
by phillc54
John,
You are welcome, I actually find it kinda therapeutic...
Cheers, Phill.
Cheers, Phill.
- Thank you received: 7491
7 years 6 months ago #130532
Replied by tommylight on topic Another plasma component...
Reaching with both hands towards 50's! There is still hope.
Sorry for not helping lately, but i had to dismantle the large plasma i was building as i just could not move through the shop any more. Will have to do a small one soon, but have to finish rearranging and making work more comfortable there. To much stuff gathered through the years and the biggest problem is small stuff, i do have plenty of it so arranging small stuff takes a week and there is no noticeable change in how the shop looks!
Keep at it, i will be following.
Regards,
Tom
Regards,
Tom
Time to create page: 0.361 seconds
