Another plasma component...
7 years 4 months ago - 7 years 4 months ago #136378 by bevins
Replied by bevins on topic Another plasma component...
You need to install glade? IT complains of no glade.
Also it pulled 2.9. this normal?
Machine configuration file is 'imperial_plasmac.ini' Starting LinuxCNC... twopass:invoked with <> options twopass:found /home/denis/linuxcnc-plasmac/lib/hallib/basic_sim.tcl twopass:found ./plasmac.hal setup_kins: cmd=loadrt trivkins coordinates=xyyz twopass:pass0: loadusr -W hal_manualtoolchange Note: Using POSIX realtime setup_kins: cmd=loadrt trivkins coordinates=xyyz APP: ./test/plasmac_test.py found: </home/denis/linuxcnc-plasmac/configs/by_machine/plasmac/gmoccapy/./test/plasmac_test.py> Traceback (most recent call last): File "/home/denis/linuxcnc-plasmac/bin/gmoccapy", line 36, in <module> import gladevcp.makepins # needed for the dialog"s calculator widget File "/home/denis/linuxcnc-plasmac/lib/python/gladevcp/__init__.py", line 1, in <module> from hal_pythonplugin import * File "/home/denis/linuxcnc-plasmac/lib/python/gladevcp/hal_pythonplugin.py", line 20, in <module> from led import HAL_LED File "/home/denis/linuxcnc-plasmac/lib/python/gladevcp/led.py", line 6, in <module> import gtk.glade ImportError: No module named glade Shutting down and cleaning up LinuxCNC... task: 13 cycles, min=0.000009, max=0.010076, avg=0.007050, 0 latency excursions (> 10x expected cycle time of 0.010000s) Note: Using POSIX realtime LinuxCNC terminated with an error. You can find more information in the log: /home/denis/linuxcnc_debug.txt and /home/denis/linuxcnc_print.txt as well as in the output of the shell command 'dmesg' and in the terminal denis@plasma01:~/linuxcnc-plasmac/src$ Traceback (most recent call last): File "/home/denis/linuxcnc-plasmac/configs/by_machine/plasmac/gmoccapy/./test/plasmac_test.py", line 28, in <module> import gladevcp.makepins File "/home/denis/linuxcnc-plasmac/lib/python/gladevcp/__init__.py", line 1, in <module> from hal_pythonplugin import * File "/home/denis/linuxcnc-plasmac/lib/python/gladevcp/hal_pythonplugin.py", line 20, in <module> from led import HAL_LED File "/home/denis/linuxcnc-plasmac/lib/python/gladevcp/led.py", line 6, in <module> import gtk.glade ImportError: No module named glade
Last edit: 7 years 4 months ago by bevins.
7 years 4 months ago #136380 by AgentWD40
Replied by AgentWD40 on topic Another plasma component...
bevins wrote: You need to install glade? IT complains of no glade.
I think we've worked it out. The issue was in the way the configurator was creating shortcuts to the config files. If it wasn't executed correctly it would create shortcuts that didn't point to the right place and understandably confuse LinuxCNC.
Yup! As of a few days ago were working on 2.9 instead of 2.8.
7 years 4 months ago - 7 years 4 months ago #136381 by bevins
Still no go. Glade installed and I can start it fine.
Machine configuration file is 'imperial_plasmac.ini' Starting LinuxCNC... twopass:invoked with <> options twopass:found /home/denis/linuxcnc-plasmac/lib/hallib/basic_sim.tcl twopass:found ./plasmac.hal setup_kins: cmd=loadrt trivkins coordinates=xyyz twopass:pass0: loadusr -W hal_manualtoolchange Note: Using POSIX realtime setup_kins: cmd=loadrt trivkins coordinates=xyyz APP: ./test/plasmac_test.py found: </home/denis/linuxcnc-plasmac/configs/by_machine/plasmac/gmoccapy/./test/plasmac_test.py> Traceback (most recent call last): File "/home/denis/linuxcnc-plasmac/bin/gmoccapy", line 36, in <module> import gladevcp.makepins # needed for the dialog"s calculator widget File "/home/denis/linuxcnc-plasmac/lib/python/gladevcp/__init__.py", line 1, in <module> from hal_pythonplugin import * File "/home/denis/linuxcnc-plasmac/lib/python/gladevcp/hal_pythonplugin.py", line 20, in <module> from led import HAL_LED File "/home/denis/linuxcnc-plasmac/lib/python/gladevcp/led.py", line 6, in <module> import gtk.glade ImportError: No module named glade Shutting down and cleaning up LinuxCNC... task: 12 cycles, min=0.000010, max=0.010071, avg=0.007441, 0 latency excursions (> 10x expected cycle time of 0.010000s) Note: Using POSIX realtime LinuxCNC terminated with an error. You can find more information in the log: /home/denis/linuxcnc_debug.txt and /home/denis/linuxcnc_print.txt as well as in the output of the shell command 'dmesg' and in the terminal denis@plasma01:~/linuxcnc-plasmac/src$ Traceback (most recent call last): File "/home/denis/linuxcnc-plasmac/configs/by_machine/plasmac/gmoccapy/./test/plasmac_test.py", line 28, in <module> import gladevcp.makepins File "/home/denis/linuxcnc-plasmac/lib/python/gladevcp/__init__.py", line 1, in <module> from hal_pythonplugin import * File "/home/denis/linuxcnc-plasmac/lib/python/gladevcp/hal_pythonplugin.py", line 20, in <module> from led import HAL_LED File "/home/denis/linuxcnc-plasmac/lib/python/gladevcp/led.py", line 6, in <module> import gtk.glade ImportError: No module named glade denis@plasma01:~/linuxcnc-plasmac/src$
7 years 4 months ago - 7 years 4 months ago #136383 by AgentWD40
bevins wrote: Still no go. Glade installed and I can start it fine.
Oh, sorry. Disregard my previous reply. I thought you were replying to yesterday's issue. For some reason when I was looking at your post on mobile it didn't show your code block.
[edit]
It looks like it's complaining that the gtk.glade module for python is missing.
Maybe try
sudo apt-get install python-gtk2 python-glade2
to install it ?
Last edit: 7 years 4 months ago by AgentWD40.
7 years 4 months ago #136385 by bevins
[edit]
Maybe try
to install it ?
Already installed
7 years 4 months ago #136421 by phillc54
Sorry but I'm not sure what is missing, you may be better off starting a thread for that here
Cheers, Phill,
Time to create page: 0.290 seconds
