Another plasma component...
7 years 4 months ago #136174 by phillc54
Do you have two Z axes?
First off try: (assuming this is the path to your git clone)
$ ~/linuxcnc-plasmac/configs/by_machine/plasmac/configurator.py
select upgrade then your ini file then upgrade and see if that changes things.
If that doesn't help can you post your ini and hal files
Cheers, Phill
7 years 4 months ago #136182 by phillc54
John,
Did that tip you gave me fix the Torch Enable button colors?
Cheers, Phill.
7 years 4 months ago - 7 years 4 months ago #136202 by AgentWD40
phillc54 wrote: Do you have two Z axes?
Two z motors.
Cheers, Phill
I'm away from the machine until this evening so I'll give it a try and update by tomorrow. But I was attempting to do a new clean config, it was nothing more than basic pncconf to get the motors jogging, then processed by the configurator.py to initialize plasmac. Same strategy I used a few days ago before 2.9
Last edit: 7 years 4 months ago by AgentWD40.
7 years 4 months ago #136205 by islander261
Phill
The torch enable button colors are working for me now. Thank you.
The following user(s) said Thank You: phillc54, rodw
7 years 4 months ago - 7 years 4 months ago #136328 by AgentWD40
Cheers, Phill
Here's the ini and hal files.
And if it matters the console was complaining about missing gmoccapy2.glade, don't know if it matters. Here's a listing of the files in the config directory:
kyle@debian:~/linuxcnc/configs/lucy$ ls -al total 88 drwxr-xr-x 2 kyle kyle 4096 Jun 8 20:14 . drwxr-xr-x 4 kyle kyle 4096 Jun 6 23:10 .. -rw-r--r-- 1 kyle kyle 1666 Jun 8 20:14 imperial_parameters.txt -rw-r--r-- 1 kyle kyle 1666 Jun 8 20:14 imperial_parameters.txt.bak lrwxrwxrwx 1 kyle kyle 22 Jun 6 23:10 imperial_startup.ngc -> ./imperial_startup.ngc -rw-r--r-- 1 kyle kyle 1348 Jun 6 23:45 lucy_connections.hal -rw-r--r-- 1 kyle kyle 13498 Jun 6 23:47 lucy.hal -rw-r--r-- 1 kyle kyle 9168 Jun 6 23:48 lucy.ini -rw-r--r-- 1 kyle kyle 600 Jun 6 23:10 lucy_material.cfg -rw-r--r-- 1 kyle kyle 316 Jun 8 20:14 lucy.pref lrwxrwxrwx 1 kyle kyle 6 Jun 6 23:10 M190 -> ./M190 lrwxrwxrwx 1 kyle kyle 19 Jun 6 23:10 materialverter.py -> ./materialverter.py lrwxrwxrwx 1 kyle kyle 20 Jun 6 23:10 metric_startup.ngc -> ./metric_startup.ngc -rw-r--r-- 1 kyle kyle 13469 Jun 6 23:10 _original_Base.hal -rw-r--r-- 1 kyle kyle 5148 Jun 6 23:10 _original_Base.ini lrwxrwxrwx 1 kyle kyle 23 Jun 6 23:10 plasmac_buttons.glade -> ./plasmac_buttons.glade lrwxrwxrwx 1 kyle kyle 21 Jun 6 23:10 plasmac_buttons.hal -> ./plasmac_buttons.hal lrwxrwxrwx 1 kyle kyle 20 Jun 6 23:10 plasmac_buttons.py -> ./plasmac_buttons.py lrwxrwxrwx 1 kyle kyle 22 Jun 6 23:10 plasmac_config.glade -> ./plasmac_config.glade lrwxrwxrwx 1 kyle kyle 20 Jun 6 23:10 plasmac_config.hal -> ./plasmac_config.hal lrwxrwxrwx 1 kyle kyle 19 Jun 6 23:10 plasmac_config.py -> ./plasmac_config.py lrwxrwxrwx 1 kyle kyle 23 Jun 6 23:10 plasmac_control.glade -> ./plasmac_control.glade lrwxrwxrwx 1 kyle kyle 21 Jun 6 23:10 plasmac_control.hal -> ./plasmac_control.hal lrwxrwxrwx 1 kyle kyle 20 Jun 6 23:10 plasmac_control.py -> ./plasmac_control.py lrwxrwxrwx 1 kyle kyle 18 Jun 6 23:10 plasmac_gcode.py -> ./plasmac_gcode.py -rw-r--r-- 1 kyle kyle 2266 Jun 6 23:10 plasmac.hal lrwxrwxrwx 1 kyle kyle 23 Jun 6 23:10 plasmac_monitor.glade -> ./plasmac_monitor.glade lrwxrwxrwx 1 kyle kyle 21 Jun 6 23:10 plasmac_monitor.hal -> ./plasmac_monitor.hal lrwxrwxrwx 1 kyle kyle 20 Jun 6 23:10 plasmac_monitor.py -> ./plasmac_monitor.py lrwxrwxrwx 1 kyle kyle 19 Jun 6 23:10 plasmac_run.glade -> ./plasmac_run.glade lrwxrwxrwx 1 kyle kyle 17 Jun 6 23:10 plasmac_run.hal -> ./plasmac_run.hal lrwxrwxrwx 1 kyle kyle 16 Jun 6 23:10 plasmac_run.py -> ./plasmac_run.py lrwxrwxrwx 1 kyle kyle 21 Jun 6 23:10 plasmac_stats.glade -> ./plasmac_stats.glade lrwxrwxrwx 1 kyle kyle 19 Jun 6 23:10 plasmac_stats.hal -> ./plasmac_stats.hal lrwxrwxrwx 1 kyle kyle 18 Jun 6 23:10 plasmac_stats.py -> ./plasmac_stats.py -rw-r--r-- 1 kyle kyle 519 Jun 6 23:10 postgui.hal lrwxrwxrwx 1 kyle kyle 11 Jun 6 23:10 README.md -> ./README.md lrwxrwxrwx 1 kyle kyle 10 Jun 6 23:10 tool.tbl -> ./tool.tbl
7 years 4 months ago #136329 by phillc54
It seems all your links are pointing back to themselves.
mkardasi had the same problem here
Do you have a recent version, if not then download the latest and try the configurator command I gave you earlier.
I have no idea what gmoccapy2.glade is.
Cheers, Phill
Time to create page: 0.173 seconds
