- Thank you received: 2100
thefabricator03 wrote: I want to say Thanks Phill for all of your hard work.
I did have a harrowing day trying to install Plasmac,
Now that I have set the basics up on my computer I will set up my machine and hopefully be cutting some steel!
phillc54 wrote: If something doesn't look like it should then check out the first post on this thread, I update it every (almost) time that I change things.
I know it is a pain with so many changes but they should taper off as we get closer to the end.
Cheers, Phill.
If it helps to spur you on, I cut a full sheet of parts today on my half sheet machine with plasmac. (I had to index the sheet twice) I am not running the latest version but the only issue I had was warpage exceeding the probe height on one pierce but I was able to recover by holding the sheet down until it finished probing.
