- Thank you received: 96
rodw wrote: jimcolt
One of the overlooked components in a THC is the mechanical tightness as well as the lack of "overshoot" of the z axis lifter. A loose lifter requires that the voltage range (deadband) is loosened up, a lifter that does not instantly stop (braking) will do the same. The z axis lifter, properly designed will be the most costly part of any THC.
You remind me of Tommy. Hes the expert of ghetto builds!AgentWD40 wrote: Fantastic info. Thank you.
That's an interesting bit of info for me to keep in mind as I build. lol, I got about $50 in my z axis lifter!
I have about AUD80 in mine plus some time and scrap bin parts for the breakaway and float switch.That's an interesting bit of info for me to keep in mind as I build. lol, I got about $50 in my z axis lifter!
AgentWD40 wrote: I certainly wouldn't argue with checking its calibration. I checked my thcad-10 with a 9.5v wall wart and a voltage divider circuit with a potentiometer. I checked it at several different voltages over the 10v range. The calculated voltage using Mesa's calibration frequencies matched my multimeter within 0.1 volts. Speaking just from my gut I think I trust mesa's calibration better than my multimeter. it's a cheapo meter, so I suppose that's the best I can do.
[edit]
Maybe another calculator for the user to plug in a series of their own frequency vs known voltage pairs and do a simple linear regression? let the user decide what they trust. I'm just thinking about convenience for the user. I would offer to do it but I know squat about gui programming in linux... maybe it's a good time to learn though
[edit x2]
Here's my test data. It was closer to +-0.03 volts, not 0.1v.
image missing https://i.imgur.com/JLdmA0I.png
