- Thank you received: 2100
From the plasma machine so all components are in play.What do you mean real voltages? Calibrate with the actual plasma machine running? Or apply a known voltage to the plasma machine's voltage divider? If so is that a trivial task?
No, nor would using theoretical results, but using the actual plasma voltage would have.Yes but the 9 volt test would not have picked up the fault I experienced and it was not related to the THCAD at all. The main problem I had was that the THCAD saw the simple resistor divider network on the Everlast board as part of its divider network so that the 16:1 divider I was using was actually 24:1. This is not a problem with my Thermal Dynamics or I believe the Hypertherm units who have much more sophisticated circuitry on their divider board.
Not everyone has a HT or TD machine and not everyone has a CNC port...
Any way there are bigger fish to fry than worrying about the "correct" way to calibrate...
Cheers, Phill.
Absloutely. In fact using the raw arc voltage is actually far easier for people inthat situation as you have total control about what the THCAD receives as you are not dependent on anybody else's dubious quality electronics!
Just so I'm all clear, all you're saying is to cut some metal with the torch or fire it in the air, with a multimeter on the thcad inputs, and watch the multimeter vs voltage-out to check calibration?phillc54 wrote:
phillc54 wrote: Any way there are bigger fish to fry than worrying about the "correct" way to calibrate...
- run LinuxCNC
- open halshow and watch plasmac.arc-voltage-in and plasmac.arc-voltage-out
- set Voltage Scale in the Plasma Config tab to 1
- set Voltage Offset in the Plasma Config tab to the value read from plasmac.arc-voltage-in
- apply a known voltage to the TCHCAD input < ---- this part here is what loses me as a complete newbie
- set Voltage Scale in the Plasma Config tab to (known-voltage / plasmac.arc-voltage-out)
you could probably keep tweaking to fine tune further.
Do a short cut with THC disabled and measure the raw arc voltage from the machine.Just so I'm all clear, all you're saying is to cut some metal with the torch or fire it in the air, with a multimeter on the thcad inputs, and watch the multimeter vs voltage-out to check calibration?
phillc54 wrote: Rod, did you try the change to the glade file for the button color?
Cheers, Phill.
