Another plasma component...
  • phillc54
  • phillc54's Avatar Topic Author
  • Platinum Member
  • Platinum Member
01 Jun 2019 05:46 #135540 by phillc54
I will have to defer to the cutters for this. I would attempt to get it as close as possible. I guess the amount of noise you get would be the limiting factor.
Cheers, Phill.
01 Jun 2019 05:58 #135541 by rodw
Got it! I thank you guys for your patience.
What's the +- tolerance or how close does the calculated voltage need to be to the raw arc voltage for a good cut?
Well, here is another quote from Jim Colt from Hypertherm. The rule of thumb is that volts change at a rate of about 10 volts per mm.
jimcolt ยป Sat May 09, 2015 8:30 am
Most height controls accurately control arc voltage to plus or minus about 2-3 volts. For every volt you will see roughly a .004"(0.1mm) change in height (this varies a bit with thickness and power levels). Controlling the arc voltage tighter than this usually creates some oscillation in the z axis, which will show as striations (roughness) in the cut edge.
I think it is funny when THC manufacturers advertise .5 volts accuracy......because the arc voltage itself fluctuates more than this (due to the moving cathode attachment).....which means the height control will oscillate rapidly up/down to try to compensate. In all cases when the edge gets rough because of this oscillation, you need to slow down the z axis speed or deaden the THC reaction time, which ultimately loosens up the voltage deadband to at least the 2-3 volt range. In reality controlling to plus or minus 5 volts is ok on materials thicker than .125".
One of the overlooked components in a THC is the mechanical tightness as well as the lack of "overshoot" of the z axis lifter. A loose lifter requires that the voltage range (deadband) is loosened up, a lifter that does not instantly stop (braking) will do the same. The z axis lifter, properly designed will be the most costly part of any THC.
In my tests sampling bout 16000 readings with hal sampler showed my Everlast changed linearly at 7.53 volts per mm and this variation had very high correlation (>99.5% confidence on the linear regression). I think the other thing going for the THCAD config is that the voltage to frequency algorithm used on the board results in a averaging of the conversion which is improved with the 1/32 frequency division as the THCAD has more time to get a good result.
I really thin LinuxCNC combined with external offsers and THCAD sampling the way Phill has tied it together achives a far better result than Jim describes in this quote.
The following user(s) said Thank You: AgentWD40
01 Jun 2019 06:21 - 01 Jun 2019 06:27 #135542 by AgentWD40
Replied by AgentWD40 on topic Another plasma component...
Fantastic info. Thank you.
jimcolt
That's an interesting bit of info for me to keep in mind as I build. lol, I got about $50 in my z axis lifter!
Last edit: 01 Jun 2019 06:27 by AgentWD40.
01 Jun 2019 07:19 #135544 by rodw
You remind me of Tommy. Hes the expert of ghetto builds!
Well it took me 3 months to build mine.
I figured If I could make that, I could make everything else!
If I did it again I'd buy a prebuilt stage and a breakaway.
  • phillc54
  • Platinum Member
  • Platinum Member
01 Jun 2019 07:22 #135545 by phillc54
I have about AUD80 in mine plus some time and scrap bin parts for the breakaway and float switch.
Cheers, Phill.
02 Jun 2019 19:47 #135653 by JTknives
Replied by JTknives on topic Another plasma component...
I certainly wouldn't argue with checking its calibration. I checked my thcad-10 with a 9.5v wall wart and a voltage divider circuit with a potentiometer. I checked it at several different voltages over the 10v range. The calculated voltage using Mesa's calibration frequencies matched my multimeter within 0.1 volts. Speaking just from my gut I think I trust mesa's calibration better than my multimeter. it's a cheapo meter, so I suppose that's the best I can do.
[edit]
Maybe another calculator for the user to plug in a series of their own frequency vs known voltage pairs and do a simple linear regression? let the user decide what they trust. I'm just thinking about convenience for the user. I would offer to do it but I know squat about gui programming in linux... maybe it's a good time to learn though
[edit x2]
Here's my test data. It was closer to +-0.03 volts, not 0.1v.
Oh crap, I completely forgot to write down the calibration numbers on the back of my board before I installed it. I would bet my voltages are a good bit off. What I did was subtract the voltage it displayed when at zero volts (this was jumping all over +-20v). Then adjusted the other number till it showed what my volt meter showed. looks like its time to dig into the controller and get a peak at that label.
02 Jun 2019 21:00 #135658 by AgentWD40
Well, from the discussion before it may not be necessary or worth the trouble. Your method may even work better depending on how much you trust your meter. Hows the quality of your cuts using mfr cut chart voltages?
02 Jun 2019 22:20 #135661 by JTknives
Its a cheep meter so i'm not sure how much i trust it. Im running a hypertherm 30xp so I dont have a cut chart. I have looked at the 45xp chart and thy say around 111v. I have played with all kinds of voltages and in my line of work im after square edges and minimum HAZ. im going to switch over to fine cut consumables today with ohmic sensing off the nozzle and try that. I would like to completely remove slag but i would rather have the big slow cut slag that is easy to remove then the tiny slag that has to be sanded off. I cant sand or grind the surfaces of the blades i cut out so easy to remove slag is key.
02 Jun 2019 22:31 #135662 by JTknives
Is there any way to add another tab that has parameters I can set that my gcodes can pull from. Does not need to be fancy just a list of say #0-30. I cut a ton of square sheets out of larger sheets. The size I cut changes depending on what the customer wants. I was planning on writing a program that has its x & y as numbered parameters that auto compute new locations as it runs. So I can enter say 6" long (in Y) and 1.5" wide (in the X) with .25 between and I want 30 of them. It would then start and zero the program where my torch is currently, do a square and move to the next position. I have done macro programming like this before but it was on a fanuc control and I could access the variable page.I was planning on moding the parameters at the beginning of the gcode but a tab would be much nicer to use.
02 Jun 2019 22:45 #135665 by rodw
JTK, if you read up on the macros in Gmocappy docs, you may be able to achieve this using the macro buttons. I think only 10 macros display but it is possible to enter variables.
Time to create page: 1.408 seconds
