Another plasma component...
- thefabricator03
- Visitor
04 Jun 2019 08:42 #135826
by thefabricator03
Thanks Phill,
Now you mention it I remember that you were updating the first post when I read through the thread a couple of months ago, The thread sure has grown since then.
Replied by thefabricator03 on topic Another plasma component...
If something doesn't look like it should then check out the first post on this thread, I update it every (almost) time that I change things.
I know it is a pain with so many changes but they should taper off as we get closer to the end.
Cheers, Phill.
Thanks Phill,
- thefabricator03
- Visitor
04 Jun 2019 08:48 #135827
by thefabricator03
I just have some table wiring to finish up, removing the CandCNC proprietary cables and installing new ohmic and encoder cables, then I should be up and cutting.
I want to say Thanks Phill for all of your hard work.
I did have a harrowing day trying to install Plasmac,
Now that I have set the basics up on my computer I will set up my machine and hopefully be cutting some steel!
If it helps to spur you on, I cut a full sheet of parts today on my half sheet machine with plasmac. (I had to index the sheet twice) I am not running the latest version but the only issue I had was warpage exceeding the probe height on one pierce but I was able to recover by holding the sheet down until it finished probing.
- islander261
- Thank you received: 216
05 Jun 2019 15:51 #135951
by islander261
Replied by islander261 on topic Another plasma component...
Phill
I started and did a fresh clone and build of the plasmac branch because of the merging the new master. Started to test and get the following error:
I checked for the pin and sure enough it isn't there.
File "./plasmac_monitor.py", line 32, in periodic
hal.set_p('plasmac_monitor.thc-led','0')
RuntimeError: pin not foundI checked for the pin and sure enough it isn't there.
- Grotius
- Thank you received: 2349
05 Jun 2019 17:05 - 05 Jun 2019 17:06 #135961
by Grotius
Replied by Grotius on topic Another plasma component...
@John,
For now you can outcomment with the # sign for python code if there is non related code to involved to this line.
Other option is to connect a fake pin with the net command in one of the hal files. "net fakepin plasmac_monitor.thd-led yourmesafakepin"
Last edit: 05 Jun 2019 17:06 by Grotius.
- phillc54
- Thank you received: 2100
06 Jun 2019 00:03 #135989
by phillc54
Sorry about that. When I was trying to sort reverse-run I was doing plasmac stuff in a different directory and forgot to copy the new plasmac_monitor.glade...
I have just pushed the fix.
If you don't want to git pull then just change the name of the thc led to thc-led and the associated label to thc-label in the glade file.
Cheers, Phill.
John,I checked for the pin and sure enough it isn't there.
Cheers, Phill.
- islander261
06 Jun 2019 01:58 #135997
by islander261
Phill
Thanks! It's not a problem, I figured you would want to know about it ASAP. We had rain showers this afternoon so I pull a painting project into the shop. I will try and cut a few sheets tomorrow.
- islander261
07 Jun 2019 04:01 #136165
by islander261
Phill
Cut two sheets today, 100% yield. Everything worked well. Like having the glaring torch enable button back. Tri color THC led gets the job done.
- AgentWD40
- Thank you received: 96
07 Jun 2019 04:18 #136166
by AgentWD40
Replied by AgentWD40 on topic Another plasma component...
Just pulled the latest and greatest and tried to build a new config. It takes a long time to load, and when it finally does it gives me this error and it loads the wrong gmoccapy then quits. This is just a bare bones config straight off the configurator.
zoom
zoom
- phillc54
07 Jun 2019 06:37 #136174
by phillc54
Do you have two Z axes?
First off try: (assuming this is the path to your git clone)select upgrade then your ini file then upgrade and see if that changes things.
If that doesn't help can you post your ini and hal files
Cheers, Phill
$ ~/linuxcnc-plasmac/configs/by_machine/plasmac/configurator.pyIf that doesn't help can you post your ini and hal files
Cheers, Phill
- phillc54
07 Jun 2019 08:05 #136182
by phillc54
John,
Did that tip you gave me fix the Torch Enable button colors?
Cheers, Phill.
Cheers, Phill.
Time to create page: 0.730 seconds
