Another plasma component...
07 Jun 2019 13:42 - 07 Jun 2019 14:28 #136202 by AgentWD40
Replied by AgentWD40 on topic Another plasma component...
Do you have two Z axes?
Two z motors.
First off try: (assuming this is the path to your git clone)
$ ~/linuxcnc-plasmac/configs/by_machine/plasmac/configurator.py
select upgrade then your ini file then upgrade and see if that changes things.
If that doesn't help can you post your ini and hal files
Cheers, Phill
I'm away from the machine until this evening so I'll give it a try and update by tomorrow. But I was attempting to do a new clean config, it was nothing more than basic pncconf to get the motors jogging, then processed by the configurator.py to initialize plasmac. Same strategy I used a few days ago before 2.9
Last edit: 07 Jun 2019 14:28 by AgentWD40.
07 Jun 2019 14:23 #136205 by islander261
Replied by islander261 on topic Another plasma component...
Phill
The torch enable button colors are working for me now. Thank you.
The following user(s) said Thank You: phillc54, rodw
09 Jun 2019 01:22 - 09 Jun 2019 01:29 #136328 by AgentWD40
Cheers, Phill
Here's the ini and hal files.
And if it matters the console was complaining about missing gmoccapy2.glade, don't know if it matters. Here's a listing of the files in the config directory:
kyle@debian:~/linuxcnc/configs/lucy$ ls -al
total 88
drwxr-xr-x 2 kyle kyle  4096 Jun  8 20:14 .
drwxr-xr-x 4 kyle kyle  4096 Jun  6 23:10 ..
-rw-r--r-- 1 kyle kyle  1666 Jun  8 20:14 imperial_parameters.txt
-rw-r--r-- 1 kyle kyle  1666 Jun  8 20:14 imperial_parameters.txt.bak
lrwxrwxrwx 1 kyle kyle    22 Jun  6 23:10 imperial_startup.ngc -> ./imperial_startup.ngc
-rw-r--r-- 1 kyle kyle  1348 Jun  6 23:45 lucy_connections.hal
-rw-r--r-- 1 kyle kyle 13498 Jun  6 23:47 lucy.hal
-rw-r--r-- 1 kyle kyle  9168 Jun  6 23:48 lucy.ini
-rw-r--r-- 1 kyle kyle   600 Jun  6 23:10 lucy_material.cfg
-rw-r--r-- 1 kyle kyle   316 Jun  8 20:14 lucy.pref
lrwxrwxrwx 1 kyle kyle     6 Jun  6 23:10 M190 -> ./M190
lrwxrwxrwx 1 kyle kyle    19 Jun  6 23:10 materialverter.py -> ./materialverter.py
lrwxrwxrwx 1 kyle kyle    20 Jun  6 23:10 metric_startup.ngc -> ./metric_startup.ngc
-rw-r--r-- 1 kyle kyle 13469 Jun  6 23:10 _original_Base.hal
-rw-r--r-- 1 kyle kyle  5148 Jun  6 23:10 _original_Base.ini
lrwxrwxrwx 1 kyle kyle    23 Jun  6 23:10 plasmac_buttons.glade -> ./plasmac_buttons.glade
lrwxrwxrwx 1 kyle kyle    21 Jun  6 23:10 plasmac_buttons.hal -> ./plasmac_buttons.hal
lrwxrwxrwx 1 kyle kyle    20 Jun  6 23:10 plasmac_buttons.py -> ./plasmac_buttons.py
lrwxrwxrwx 1 kyle kyle    22 Jun  6 23:10 plasmac_config.glade -> ./plasmac_config.glade
lrwxrwxrwx 1 kyle kyle    20 Jun  6 23:10 plasmac_config.hal -> ./plasmac_config.hal
lrwxrwxrwx 1 kyle kyle    19 Jun  6 23:10 plasmac_config.py -> ./plasmac_config.py
lrwxrwxrwx 1 kyle kyle    23 Jun  6 23:10 plasmac_control.glade -> ./plasmac_control.glade
lrwxrwxrwx 1 kyle kyle    21 Jun  6 23:10 plasmac_control.hal -> ./plasmac_control.hal
lrwxrwxrwx 1 kyle kyle    20 Jun  6 23:10 plasmac_control.py -> ./plasmac_control.py
lrwxrwxrwx 1 kyle kyle    18 Jun  6 23:10 plasmac_gcode.py -> ./plasmac_gcode.py
-rw-r--r-- 1 kyle kyle  2266 Jun  6 23:10 plasmac.hal
lrwxrwxrwx 1 kyle kyle    23 Jun  6 23:10 plasmac_monitor.glade -> ./plasmac_monitor.glade
lrwxrwxrwx 1 kyle kyle    21 Jun  6 23:10 plasmac_monitor.hal -> ./plasmac_monitor.hal
lrwxrwxrwx 1 kyle kyle    20 Jun  6 23:10 plasmac_monitor.py -> ./plasmac_monitor.py
lrwxrwxrwx 1 kyle kyle    19 Jun  6 23:10 plasmac_run.glade -> ./plasmac_run.glade
lrwxrwxrwx 1 kyle kyle    17 Jun  6 23:10 plasmac_run.hal -> ./plasmac_run.hal
lrwxrwxrwx 1 kyle kyle    16 Jun  6 23:10 plasmac_run.py -> ./plasmac_run.py
lrwxrwxrwx 1 kyle kyle    21 Jun  6 23:10 plasmac_stats.glade -> ./plasmac_stats.glade
lrwxrwxrwx 1 kyle kyle    19 Jun  6 23:10 plasmac_stats.hal -> ./plasmac_stats.hal
lrwxrwxrwx 1 kyle kyle    18 Jun  6 23:10 plasmac_stats.py -> ./plasmac_stats.py
-rw-r--r-- 1 kyle kyle   519 Jun  6 23:10 postgui.hal
lrwxrwxrwx 1 kyle kyle    11 Jun  6 23:10 README.md -> ./README.md
lrwxrwxrwx 1 kyle kyle    10 Jun  6 23:10 tool.tbl -> ./tool.tbl
Last edit: 09 Jun 2019 01:29 by AgentWD40.
  • phillc54
  • phillc54's Avatar Topic Author
  • Platinum Member
  • Platinum Member
09 Jun 2019 01:36 #136329 by phillc54
It seems all your links are pointing back to themselves.
mkardasi had the same problem here
Do you have a recent version, if not then download the latest and try the configurator command I gave you earlier.
I have no idea what gmoccapy2.glade is.
Cheers, Phill
09 Jun 2019 01:52 #136332 by islander261
Phill etal
Don't worry about the second screen for Gmoccapy. Everyone's install checks for it and no one has a second screen that I have seen. If one of the Python Gurus wants to get rid i of this on their install I am sure that commenting out the appropriate lines in the Gmoccapy Python handler file will cure it.
09 Jun 2019 02:16 - 09 Jun 2019 02:21 #136334 by AgentWD40
Yes. pulled just now.
Ok I see what you're doing. The links that are created in the config directory are relative to the directory the configurator is called from. I called the configurator and 'upgraded' from both ~/ and ~/plasmac (my install directory). Neither of these worked. I finally just deleted the links and copied over the files directly and it's working now without links.
Last edit: 09 Jun 2019 02:21 by AgentWD40.
  • phillc54
  • Platinum Member
  • Platinum Member
09 Jun 2019 02:22 #136336 by phillc54
Yes, the configurator is run in the same directory the original plasmac source is.
When you do an upggrade you enter the inifile path/name of the configuration you want to upgrade.
The disadvantage of using actual file copies is that you need to recopy any files that have been upgraded whereas with links if they are pointing to the correct location then that is not necessary.
Cheers, Phill.
09 Jun 2019 02:27 - 09 Jun 2019 02:28 #136338 by AgentWD40
Any clue why mine aren't working? The paths that were created in my case were in the form of ./plasmac/configs/..., should they start with a ~ instead of a dot. Maybe it would be more bulletproof if the links used full paths?
Last edit: 09 Jun 2019 02:28 by AgentWD40.
09 Jun 2019 02:44 #136339 by AgentWD40
I changed line #73 of configurator.py to
self.copyPath = os.path.dirname(os.path.abspath(__file__))
in order to get the links to use full path names and it seems to have worked. My new config loads just fine.
  • phillc54
  • Platinum Member
  • Platinum Member
09 Jun 2019 02:45 #136340 by phillc54
It is hard to give full paths because not everyone will put their clone into /home/{USERNAME}/linuxcnc-plasmac/
I have run the configurator from different paths that were real clones and have not had a problem. I have used both Stretch, Wheezy and LMDE2.
Cheers, Phill.
Time to create page: 0.295 seconds
