Another plasma component...
7 years 5 months ago - 7 years 5 months ago #135522 by phillc54
I believe Mesa calibrations are 100% accurate, what I mean is the tolerances of the divider components, also don't forget some users will be making their own divider as they don't have a CNC port on their machines.
I also mean a 'real' voltage on the THCAD input, not a battery on a test bench.
Rod, I seem to recall you had problems with the divider in your Everlast machine.
Cheers, Phill.
Last edit: 7 years 5 months ago by phillc54.
7 years 5 months ago - 7 years 5 months ago #135523 by AgentWD40
rodw wrote: Very nice. I must confess I don't use Plasmac's scaling and have stuck with the component I wrote ages ago which does the same thing as your web calculator forum.linuxcnc.org/plasma-laser/32585-scalethcad-component . So I use scaling as 1 and offset as 0 and give plasmac the torch volts already scaled.
I did install your component the other day but never got a chance to look at it or configure it as I was having other issues just getting readings (you might remember). Now that I look at it it looks like exactly what thcad users need.
That said, in the spirit of plasmac being all inclusive of all hardware, I'm still thinking it would be nice for users to have a gui to calculate their hardware's settings to work with the single generic plasmac component?
Stop me if I'm making this harder than it needs to be. I know I tend to over complicate things sometimes.
Last edit: 7 years 5 months ago by AgentWD40.
7 years 5 months ago #135524 by phillc54
Don't get me wrong, I am just stating my preference for setup, I find it so simple to do and there is no concern with any component tolerances.
By all means go ahead with your GUI, I will be happy to include it in the plasmac config when you have it finished. If you add a bit of a blurb I will include that in the readme as well.
Cheers, Phill.
7 years 5 months ago #135525 by AgentWD40
phillc54 wrote: I believe Mesa calibrations are 100% accurate, what I mean is the tolerances of the divider components, also don't forget some users will be making their own divider as they don't have a CNC port on their machines.
Cheers, Phill.
What do you mean real voltages? Calibrate with the actual plasma machine running? Or apply a known voltage to the plasma machine's voltage divider? If so is that a trivial task?
7 years 5 months ago #135526 by rodw
phillc54 wrote: Rod, I seem to recall you had problems with the divider in your Everlast machine.
Cheers, Phill.
Yes but the 9 volt test would not have picked up the fault I experienced and it was not related to the THCAD at all. The main problem I had was that the THCAD saw the simple resistor divider network on the Everlast board as part of its divider network so that the 16:1 divider I was using was actually 24:1. This is not a problem with my Thermal Dynamics or I believe the Hypertherm units who have much more sophisticated circuitry on their divider board.
So if you are using a cheap plasma cutter and are getting odd results, compare the result via the divider board and from raw arc voltage with the proper THCAD scaling resistance (remember to include the resistance the plasma manufacturer includes in the circuit usually 200k). I actually did this with my Thermal Dynamics to check it was all good as it only took a couple of minutes to solder in a resistor so I know my TD divider board is correct.
I did manage to fry a THCAD at one stage but that is another story but I know for certain from that that each THCAD is individually calibrated.
7 years 5 months ago - 7 years 5 months ago #135527 by rodw
AgentWD40 wrote: What do you mean real voltages? Calibrate with the actual plasma machine running? Or apply a known voltage to the plasma machine's voltage divider? If so is that a trivial task?
Ummm see my last post. I actually only isolated the fault once I connected two 48V power supplies in series to give me 96 volts and ran it through the divider board. There was nothing on the Everlast divider board I could blow up doing this, I'd be a bit reluctant trying it on a Thermal Dynamics. I think comparing the raw arcs on a real cut vs the divided volts is a better approach (assuming the raw arc voltage is brought out onto the CPC connector).
Last edit: 7 years 5 months ago by rodw.
Time to create page: 0.731 seconds
