Another plasma component...
7 years 5 months ago #135353 by phillc54
I found a small bug with the configurator. Lines 519 and 523: these conditionals need to check from the beginning of the line eg ^MAX_VELOCITY instead of *MAX_VELOCITY. Otherwise it will fail when it encounters a line with these strings in a comment. Pncconf generated ini files will have these strings in the comments.
Thanks for the report, fixed and pushed...
Cheers, Phill.
7 years 5 months ago #135354 by phillc54
islander261 wrote: Phill
I am going off island for the next 5 to 7 days and am done for night now. If I have time in the morning I will try the test. I am using the Linux Mint system theme on the LMDE-2 machine control box.
Thanks John, I have been to the mint website and there is a Cinnamon, a Mate and a XFCE edition so I am not sure which one to try...
Cheers, Phill.
7 years 5 months ago - 7 years 5 months ago #135356 by AgentWD40
phillc54 wrote: This color button is frustrating...
Could you guys let me know the results of
lsb_release -a
on your machines.
Cheers, Phill.
My data point: I just updated to latest and the torch enabled/disabled button color works fine in gmoccapy on my debian 9.9 machine, default xfce desktop and everything from the linuxcnc stretch iso. I've also rebuilt a barebones ini/config.
Speaking of barebone config, the last hal component I need to hook up is the torch voltage. I'm running a 7i96 and a thcad10. What lines do I need to get the thc hooked up? Right now the only hal config I have in regard to this is
net plasmac:arc-voltage-in hm2_7i96.0.encoder.00.velocity => plasmac.arc-voltage-in
But it's just a placeholder to get the config to load until I figure out what it's supposed to be. All I know is i'm to wire into encoder A and somehow calibrate with the sticker on the back of the thcad card. I know the THCAD manual has a simple formula for converting the frequency to voltage with these calibration figures, but when I was looking through plasmac.comp I didn't see where I use these.
Last edit: 7 years 5 months ago by AgentWD40.
7 years 5 months ago #135357 by phillc54
Yes, the THCAD wires into encoder A
- run LinuxCNC
- open halshow and watch plasmac.arc-voltage-in and plasmac.arc-voltage-out
- set Voltage Scale in the Plasma Config tab to 1
- set Voltage Offset in the Plasma Config tab to the value read from plasmac.arc-voltage-in
- apply a known voltage to the TCHCAD input
- set Voltage Scale in the Plasma Config tab to (known-voltage / plasmac.arc-voltage-out)
you could probably keep tweaking to fine tune further.
Basically:
Voltage Offset sets the displayed voltage to 0 when there are zero volts present.
Voltage Scale set the voltage to the correct value for a known voltage.
Cheers, Phill.
7 years 5 months ago #135358 by phillc54
Rod and/or John,
Could you please try this:
In plasmac_buttons.glade change line 4 with a text editor from:
<requires lib="gtk+" version="2.24"/>
to:
<requires lib="gtk+" version="2.18"/>
Cheers, Phill.
7 years 5 months ago #135359 by AgentWD40
- run LinuxCNC
Basically:
Cheers, Phill.
I must be missing something. plasmac.arc-voltage-in voltage-out, as well as hm2_7i96.0.encoder.00.velocity don't show anything, all zero.
Is there another component I need to load?
The thcad is blinking, and blinks faster when I put voltage on the input. I tried F/1 and F/32. Also, the bipolar/unipoler jumper is confusing referencing the silkscreen vs the manual.
Time to create page: 0.410 seconds
