- Thank you received: 216
Grotius wrote: @Rod,
For your previous post 29 of may post nr. 135227.
My advise for you is to use the code snipped ( on circles and small shapes ) to lower your speed
to 50-70%. Sheetcam lines will turn from green to blue where the code snipped is active.
This will result in more accurate holes and small shapes. At the moment you go to fast i see at the picture.
The post after this 29 May 2019 08:39, i marked up your plate allignment of plasma cutting is wrong in relation to the working table.
Always try to cut the long pieces the other way. Try alway's to cut the long pieces over the metal strips 90 degrees.
See this as your nesting protocol !
And in the end. Why don't you have a water table? This will end in a much more accurate product.
I made my second plasma rotary water cut option this week for a Belgium customer. Will give the forum picture coming day's.
Is this happening after the torch is turned off or before?Where the problem crops up is right at the end of a cut. If the sheet pops up right as it finishes and bumps the shield it trips out and I can’t restart it.
