- Thank you received: 32
John has set you straight on the rounding. When I first got my table moving, I drew a large square at maximum speed and it rounded the corners by many inches. So i put it in the startup code (which in plasmac's case is in a .ngc file in the config directory)JTknives wrote: Anyone know why it would start cutting round corners.
And sometimes it’s still not using the THC. It touches off and just takes off but never adjusts the Z.
Rod is on the right track here but you do not have to use the M190 and M66 lines, they are only used if you are specifying material numbers. You could omit these and it will use the parameters of the currently displayed material. You do need the F#<_hal[plasmac.cut-feed-rate]> if you want to use the displayed materials cut feed rate. If you specify a feed rate in gcode say F2000 then if that is less than 99.9% of the displayed materials cut feed rate then cornerlock will stay locked because the machine will not reach the displayed materials cut feed rate.If you have feed rates in the gcode, they will be used. To use the one set in the plasmac gui, you need to add
M190 Pn
M66 P3 L3 Q1
M3 S1
Have a look in imperial_startup.ngc, I have specified G64 P0.04 (1mm), it should have been 0.004 (0.1mm) it is correct in metric_startup.ngc.Anyone know why it would start cutting round corners.
I found that it worked by removing this from the .ini file:
# required for remapping gcode f word
#REMAP = F prolog=plasmac_feed_prolog ngc=plasmac_feed epilog=plasmac_feed_epilog
So is this bit now redundant?
