Another plasma component...
7 years 5 months ago #135048 by phillc54
rodw wrote: I mad the mistake of doing a massive back yard makeover which includes a lot of lawn and pop up sprinklers a couple of years ago so I feel for John becasue I chose a slow growing grass variety!
I put artificial grass in and sold the lawnmower, happy days...
Cheers, Phill.
7 years 5 months ago #135050 by rodw
So that was after you started writing plasmac I take it?
7 years 5 months ago #135053 by pl7i92
Replied by pl7i92 on topic Another plasma component...
phillc54 wrote: I have pushed some updates.
Changes to plasmac.comp so you need to run make.
A change to the kerf crossing calculations for anyone who is game to try it...
Some minor changes to:
configs/by_machine/plasmac/axis/metric_plasmac.ini
configs/by_machine/plasmac/axis/imperial_plasmac.ini
configs/by_machine/plasmac/test/plasmac_test.py
nc_files/plasmac/imperial_wrench.ngc
Cheers, Phill
ARE this files now in master
or only on the git
7 years 5 months ago #135058 by rodw
pl7i92 wrote: ARE this files now in master
or only on the git
These files will never be in master until the reverse run branch is in master. That is the only reason why Phill is forced to keep his private repository. BUt he keeps it current with master branch
7 years 5 months ago #135071 by JTknives
Anyone know why it would start cutting round corners. I was cutting sheets out and stopped to run to town. Came back and I tweaked some cut speed settings. And it started doing this. I don’t have a G02/G03 any where in the program. I closed LinuxCNC and still doing it. I also dropped cut speed to 50%. I changed feed rate from 100in/min to 200 in/min in the program file. This also brings up another weird thing. It seams to be running off the feed rate in the program not the feed rate set in the settings. And sometimes it’s still not using the THC. It touches off and just takes off but never adjusts the Z.
7 years 5 months ago #135073 by islander261
JTknives
My guess is that you are not setting your G64 correctly. Look in the docs!
I use G64 P0.010 Q0.005 for most plasma work.
Time to create page: 0.656 seconds
