- Thank you received: 2100
That would be perfect if possible but I cannot justify the cost for a hobby machine so I will also be modifying my 30XP that my employer bought for me when I retired.My advice is to sell your current machine and buy a model which has the CPC port. Upgrade to a proper machine torch while your at it. Its a shame to see these great machines being built and then still using a hand torch.
No, No and Yes.So the 30XP does not come with a CPC port? Can one be added? Does that option start at the 45 amp models?
The 30XP is a hand machine only, it doesn't even have a plug in torch. It's a bit restrictive but it is what I have and I am sure it will perform great for what I will be doing.
Cheers, Phill.
thefabricator03 wrote: Judging from the videos JT has posted it looks like it has the same cut quality as its large cousins.
What do you plan to cut with your machine Phil?
