Another plasma component...
7 years 5 months ago #134655 by rodw
Try adding a debounce to your float switch so a spurious trigger needs to stay on for a while before its seen.
If you pulse the torch from the GUI, does it come on? If not, you may have a wiring issue.
I don't think polarity on the opto22 will be a problem. Islander will know for sure.
7 years 5 months ago #134660 by JTknives
I will run some tests tonight but yes a pulse from the GUI will fire it 100%. My float switch is crazy touchy as it’s from a tool setter on a mill. So it does not take much to trip it, maybe .005. It’s so touchy that if the shield touches the steel it trips it. I soldered my switch wires right to the board. If you look on the other side of the 30XP there is 2 holes labeled start lol all ready drilled and primed for soldering.
7 years 5 months ago #134668 by billykid
well now everything works .. I put a relay on torch-on that closes arc-ok and the entrance to the thcad so by adjusting the voltage the z axis goes up and down.
now I have to mount it on the small cnc with an inteco eagle 35 plasma without hf.
thank you
mauro
if you want to laugh, here is the photo of my test bench :-)
The following user(s) said Thank You: phillc54, chimeno, Clive S, rodw
7 years 5 months ago #134723 by JTknives
So I had another weird issue today and it might have been fixed in the current update. I found I can’t have the curf crossing lock on. It would lock the z at its start height and just start cutting. Now it would not do it all the time but one time it did I looked at the screen and noticed the light on the GUI was on. So turned it off and the problem disappeared.
7 years 5 months ago #134741 by rodw
JTknives wrote: So I had another weird issue today and it might have been fixed in the current update. I found I can’t have the curf crossing lock on. It would lock the z at its start height and just start cutting. Now it would not do it all the time but one time it did I looked at the screen and noticed the light on the GUI was on. So turned it off and the problem disappeared.
The one cut I did with kerf crossing using halscope showed that the Kerf crossing signal was enabled before the kerf was encountered. Its still very much experimental and Phill needs to get his table built to go further with this. I would just leave it turned off.
7 years 5 months ago #134746 by Grotius
Replied by Grotius on topic Another plasma component...
JTKnives,
You know, when you have a HP XP30. You may not solder on the HP's internal circuit's, warranty is lost and gone at that moment.
Using the hand torch trigger external is no problem i expect for HP warranty. But that is not for sure. In my case they could accept it as warranty, but in your case i don't know it for sure.
Please stay off HP's internal circuit's. Use CPC 3 & 4 for exernal torch start & 5 + 6 for torch height control in combination with internal dip switch for optimal thc resolution.
Time to create page: 0.663 seconds
