No metal, please! I've already seen one such incident, did not end well !JTknives wrote: .... Turn a body for it and ....
Sheetcam has it as "kerf" under "tool" i think, it's been to long since i tested it.JTknives wrote: lol, yeah no steel. I don’t know your customer but I would halfway assume that would be common knowledge.
So another question. Does or can LinuxCNC/plasmaC apply cutter comp. I looked through Sheetcam and did not see any options to turn it on. I would like to beable to adjust offset on the fly so I can fine tune the size of the parts.
Yes you can, this is from the readme:JTknives wrote: So another question. Does or can LinuxCNC/plasmaC apply cutter comp. I looked through Sheetcam and did not see any options to turn it on. I would like to beable to adjust offset on the fly so I can fine tune the size of the parts.
This uses kerf width from the selected material.To use cutter compensation you will need to use G41.1, G42.1 and G40 with the cut file parameter hal pin #<_hal[plasmac_run.kerf-width-f]> like so:
- G41.1 D#<_hal[plasmac_run.kerf-width-f> ; for left of programmed path
- G42.1 D#<_hal[plasmac_run.kerf-width-f> for right of programmed path
- G40 to turn compensation off
