Another plasma component...
7 years 5 months ago #135331 by sevaz
Replied by sevaz on topic Another plasma component...
I saw the missing color button issue. But in my case, it depends on gtk theme: so with some themes(usually xfce default one) everything works fine, but another i see no color at all.
I tested it on debian 7 and mint 19
7 years 5 months ago - 7 years 5 months ago #135332 by islander261
Phill
Please find attached requested files. I tried to set the theme to follow system with no change.
Last edit: 7 years 5 months ago by islander261.
7 years 5 months ago - 7 years 5 months ago #135333 by phillc54
John,
If you get a spare minute could you try this:
comment out line 203 in plasmac_buttons.py which is "self.set_theme()" and see if that has any effect.
Cheers, Phill.
Edit:
Does the button have no color at all or is it stuck on one color?
Last edit: 7 years 5 months ago by phillc54.
7 years 5 months ago #135334 by rodw
phillc54 wrote: John,
Cheers, Phill.
Edit:
No change Phil. The buttons have the default background colour in all states
7 years 5 months ago #135335 by phillc54
Thanks Rod,
Are you running from a terminal? If so do you get any messages in the terminal when you click the button?
Cheers, Phill
7 years 5 months ago - 7 years 5 months ago #135336 by phillc54
Rod and John,
What is your default system theme?
Cheers, Phill.
Edit:
I did manage to see this anomaly.
It happens here because Gmoccapy lets me select a theme that is not installed on my system.
Plus in my system appearances I can also select a theme (Adwaita) that is not installed...
Time to create page: 0.795 seconds
