Another plasma component...
7 years 5 months ago #135439 by phillc54
Thanks John,
I managed to find LMDE2 and made a new virtual machine last night, loaded all the dependencies, cloned plasmac and built LinuxCNC.
The colors work fine, I really don't know where to go from here...:(
Did you guys try the mod to the glade file?
Cheers, Phill.
7 years 5 months ago - 7 years 5 months ago #135473 by AgentWD40
You guys think a THCAD calibration setting calculator like this would be a useful addition to something like the configurator?
jscalc.io/calc/NTr5QDX6WgMThBVb
[edit]
I hope it works right because I can't figure out how to get back in to edit the stupid thing.. anyway I figure
scale = thcad_model_voltage * frequency_divider * plasma_divider_ratio / (max_voltage_frequency - zero_voltage_frequency)
offset = zero_voltage_frequency / frequency_divider
where max_voltage_frequency and zero_voltage_frequency are from the calibration sticker x1000
Last edit: 7 years 5 months ago by AgentWD40.
7 years 5 months ago #135504 by rodw
AgentWD40 wrote: You guys think a THCAD calibration setting calculator like this would be a useful addition to something like the configurator?
[edit]
Very nice. I must confess I don't use Plasmac's scaling and have stuck with the component I wrote ages ago which does the same thing as your web calculator forum.linuxcnc.org/plasma-laser/32585-scalethcad-component . So I use scaling as 1 and offset as 0 and give plasmac the torch volts already scaled.
7 years 5 months ago #135510 by phillc54
I still think that at the end you will need to check it against a known voltage as component tolerances will make a difference.
Although I guess if you are not intending to use the voltage from manufacturers cut charts then it probably doesn't matter too much.
Cheers, Phill.
7 years 5 months ago - 7 years 5 months ago #135518 by AgentWD40
I certainly wouldn't argue with checking its calibration. I checked my thcad-10 with a 9.5v wall wart and a voltage divider circuit with a potentiometer. I checked it at several different voltages over the 10v range. The calculated voltage using Mesa's calibration frequencies matched my multimeter within 0.1 volts. Speaking just from my gut I think I trust mesa's calibration better than my multimeter. it's a cheapo meter, so I suppose that's the best I can do.
[edit]
Maybe another calculator for the user to plug in a series of their own frequency vs known voltage pairs and do a simple linear regression? let the user decide what they trust. I'm just thinking about convenience for the user. I would offer to do it but I know squat about gui programming in linux... maybe it's a good time to learn though
[edit x2]
Here's my test data. It was closer to +-0.03 volts, not 0.1v.
image missing https://i.imgur.com/JLdmA0I.png
7 years 5 months ago #135520 by rodw
phillc54 wrote: I still think that at the end you will need to check it against a known voltage as component tolerances will make a difference.
Cheers, Phill.
But each board is individually calibrated by Mesa so there is no need to do this as most won't have a lab quality power supply at their disposal. Testing with a 9 volt battery is only useful as a simple check to see that you have it set up in the ball park in hal show. Eg frequency count is at 90% of the range.
Time to create page: 1.034 seconds
