Low budget plasma setup, what do I need?
- Thank you received: 4656
29 Apr 2019 09:22 #132292
Replied by andypugh on topic Low budget plasma setup, what do I need?
A lack of real output bearings (or, in fact, a real output shaft) is definitely a concern with that 3D printed reducer.
Also, the video seems to suggest an awful lot of backlash.
On reflection, a 3D printed Harmonic reducer is a much more interesting idea...
- tecno
- Thank you received: 127
29 Apr 2019 09:30 #132294
by tecno
Replied by tecno on topic Low budget plasma setup, what do I need?
I agree, will take a lot of trial and error modifying parts to that 6:1 reducer good.
Have you seen any harmonic reducers with 5:1 or 6:1 ? 3D printed that is?
29 Apr 2019 10:29 #132299
No. I was thinking about 120:1 for robots.
29 Apr 2019 10:32 #132300
Already been done, it seems.
www.thingiverse.com/search?q=Harmonic+Drive&dwh=375cc718e136395
- tecno
01 May 2019 02:32 #132415
by tecno
Peter, can you help me and add code for one 7i37 as I need some inputs. That would be much appreciated.
freeby.mesanet.com/7i90_plasma.zip
Contains the correct bitfile (8 stepgens, 2 PWM gens and 2 "A" pin only encoders on I/O 0..23)
The one in the dist is broken, will fix tomorrow
01 May 2019 06:31 #132426
Does the firmware have any smart-serial channels? That might be a more efficient way to add GPIO pins.
01 May 2019 06:32 - 01 May 2019 06:32 #132428
I see that you have the crossed-roller way and so are using that, but did you see the posts where I suggested that there are some guided pneumatic cylinders that look perfect for the job of being a lockable floating mount?
Last edit: 01 May 2019 06:32 by andypugh.
- tecno
01 May 2019 06:43 #132429
by tecno
But that would need another board and I have the 7i37 already.
- tecno
01 May 2019 07:15 #132430
by tecno
OK, yes it could work but again that would be something I´d have to buy = I will have to make do with what I have at hand.
- Thank you received: 5337
01 May 2019 13:34 #132453
Replied by PCW on topic Low budget plasma setup, what do I need?
There is no "code" for a 7I37, all I/O is just GPIO
The first 16 GPIO on a connector with a 7I37 are inputs
The last 8 GPIO on a connector with a 7I37 are outputs
and these 8 GPIO must be set to output mode
The following user(s) said Thank You: tecno
Time to create page: 0.144 seconds
